Fujitsu B24-8 TE Pro 23.8" 1920x1080 5ms VGA DVI Display...
Fujitsu B24-8 TE Pro 23.8" 1920x1080 5ms VGA DVI DisplayPort LED Mon
£238.11
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Excellent visual performance with wide viewing angle panel technology
  • Convenient and fatigue-proof longtime-usage with oustanding visual ergonomics for the office
  • Optimized and relaxed position - with ergonomic stand featuring height adjust, swivel, tilt and 90° rotation
  • Flexible connectivity with DisplayPort, DVI, Analog and USB
  • Smart design with space-saving front frame and smart details like discretely integrated speakers and cable guide for a clean desk
  • Environment-friendly LED technology with unique, highly efficient energy-saving solutions like ECO operation mode and ECO standby
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £241.60
Save £1.50
The FUJITSU display B24-8 TE Pro is made for intensive office work. With visual and mechanical ergonomics this display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Product Description Fujitsu B24-8 TE Pro - Business Line - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class A+
Energy Consumption per Year 28 kWh
Power Consumption (On mode) 19 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Marble grey
Dimensions (WxDxH) - with stand 55.3 cm x 22.94 cm x 34.7 cm
Weight 5.6 kg
Localisation United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, TUV S, CCC, RoHS, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, ISO9241-307, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu B24-8 TE Pro 2...
£238.11
