Fujitsu B24W-7 24" 1920x1200 5ms VGA DVI DisplayPort LED...
Fujitsu B24W-7 24" 1920x1200 5ms VGA DVI DisplayPort LED IPS Monitor
£292.09
Delivery:
Key features
  • Exceeding ergonomics
  • Eco system
  • LED backlight technology
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The FUJITSU B24W-7 LED display with excellent ergonomics makes intensive office work extremely comfortable. This highly reliable display offers superb usability and power-saving features to help reduce your labor as well as energy costs. With wide viewing angle technology, flexible connectivity, and easy manageability, the FUJITSU B24W-7 LED display can help you improve productivity.
Product Description Fujitsu B24W-7 LED - Business Line - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A+
Energy Consumption per Year 28 kWh
Power Consumption (On mode) 19 W
Features USB 2.0 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Marble grey
Dimensions (WxDxH) - with stand 55.9 cm x 20.4 cm x 38.4 cm
Weight 6.9 kg
Localisation United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, VCCI, cUL, EN 60950, GS, SASO, TUV S, DDC/CI, RoHS, ISO 9241-307, WEEE, S Mark, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu B24W-7 24" 192...
£292.09
