Fujitsu B27-8 TE 27" 1920x1080 5ms VGA DVI DP LED IPS Mo...
Fujitsu B27-8 TE 27" 1920x1080 5ms VGA DVI DP LED IPS Monitor
£290.78
Delivery:
Product codes
The FUJITSU display B27-8 TE Pro is an advanced widescreen display with 1920 x 1080 resolution that can accommodate two A4 sized documents side-by-side with ease making it ideal for document management applications in the workplace. The display delivers consistent picture quality and has a range of connectivity options ideal for medium- and large-sized businesses.
Fujitsu B27-8 TE Pro - Business Line - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
34 kWh
Power Consumption (On mode)
23 W
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
62.13 cm x 29.94 cm x 38.8 cm
6.72 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu B27-8 TE 27" 1...
£290.78
