Fujitsu B27-8 TE 27" 1920x1080 5ms VGA DVI DP LED IPS Mo...
Fujitsu B27-8 TE 27" 1920x1080 5ms VGA DVI DP LED IPS Monitor
£268.03
Delivery:
  • Diagonal Size: 27in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The FUJITSU display B27-8 TE Pro is an advanced widescreen display with 1920 x 1080 resolution that can accommodate two A4 sized documents side-by-side with ease making it ideal for document management applications in the workplace. The display delivers consistent picture quality and has a range of connectivity options ideal for medium- and large-sized businesses.
Product Description Fujitsu B27-8 TE Pro - Business Line - LED monitor - Full HD (1080p) - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A+
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Features USB 3.1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.311 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Marble grey
Dimensions (WxDxH) - with stand 62.13 cm x 29.94 cm x 38.8 cm
Weight 6.72 kg
Localisation United Kingdom
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu B27-8 TE 27" 1...
£268.03
