Fujitsu B27T-7 Pro 27" 1920x1080 5ms VGA DVI DisplayPort...
Fujitsu B27T-7 Pro 27" 1920x1080 5ms VGA DVI DisplayPort LED Monitor
Key features
  • LED technology
  • Energy efficient
  • Convenient and fatigue-proof screen
  • Optimized and relaxed position
  • Flexible connectivity
  • Representative design
Product codes
The B27T-7 Pro is made for intensive office work. With visual and mechanical ergonomics this display enables fatigue-free working for hours in front of the screen. The large screen allows you to keep always track of all open applications. This high-quality display works unfailingly around the clock. Easy connectivity, manageability and usability help you increase your productivity.
Fujitsu B27T-7 Pro - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A+
Energy Consumption per Year
27 kWh
Power Consumption (On mode)
18 W
USB Hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
64.4 cm x 22.7 cm x 40.5 cm
8.9 kg
United Kingdom
FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, CCC, DDC/CI, RoHS, WEEE, Directive 2004/108/EEC, EAC, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu B27T-7 Pro 27"...
