Fujitsu Celsius J550 Core i7-6700 8GB 1TB Windows 10 Pro
Key features
  • Easy integration into customers' existing infrastructure
  • Astounding computing power in a small form factor
  • Support of standard, full height graphics cards and legacy slots for a great customer TCO
  • The CELSIUS J550 combines powerful workstation performance and great expandability
  • Enjoy maximum viewing capabilities and increase your productivity
  • Fujitsu's desktop workstations are designed, engineered and manufactured in the heart of Europe
Product codes
If you need a powerful yet small workstation, Fujitsu's CELSIUS J550 is the ideal choice for entry-level 3D, CAD, financial applications as well as the healthcare industry. Thanks to its innovative 10 liter design, the CELSIUS J550 small form factor workstation is the first to support standard, full-height graphics cards.
Product Description Fujitsu Celsius J550 - SFF - Core i7 6700 3.4 GHz - 8 GB - 1 TB - QWERTY UK
Type Workstation - small form factor
Localisation Region: United Kingdom
Processor 1 x Intel Core i7 (6th Gen) 6700 / 3.4 GHz (4 GHz) (Quad-Core)
Processor Socket LGA1151 Socket
Processor Main Features Intel Turbo Boost Technology 2
Cache Memory 8 MB
Cache Per Processor 8 MB
RAM 8 GB (installed) / 64 GB (max) - DDR4 SDRAM - PC4-17000
Storage Controller RAID (SATA 6Gb/s)
Hard Drive 1 x 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage DVD SuperMulti
Multi-GPU Configuration 1 single GPU card / integrated GPU
Graphics Controller NVIDIA Quadro K620 / Intel HD Graphics 530 Shared Video Memory (UMA)
Video Memory 2 GB
Audio Output 5.1 channel surround
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Dimensions (WxDxH) 33.2 cm x 33.8 cm x 8.9 cm
Weight 9 kg
Manufacturer Warranty Limited warranty - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu Celsius J550 C...
