Fujitsu Esprimo X956/T Core i3-6100T 4GB 500GB Windows 10 Pro
£580.93
Delivery:
Key features
  • Easy integration into customers' existing infrastructure
  • Benefit from a neat, efficient desk and optimum working positions to work as effectively as possible
  • Be ready for instant communication and significantly reduce your energy bill
  • Enables a highly efficient workflow and supports interactive working scenarios in the office
  • Simple system administration for complex IT infrastructures and excellent levels of data protection
  • Processor Type: Core i3
  • Operating System: Windows 10 Pro 64-bit Edition
  • Installed Memory: 4GB
  • Hard Drive Capacity: 500GB, 500GB
  • Storage Type: HDD
Product codes
The sophisticated FUJITSU ESPRIMO X956/T has all the advantages of a PC plus a multi-position 23-inch touch display and innovative easy log on features. Achieve significant TCO savings with DeskView and Intel vPro technology and protect confidential data with the latest TPM controller. With the Low Power Active mode it supports a wide range of usage scenarios such as telephony and video conferencing.
Product Description Fujitsu ESPRIMO X956/T - all-in-one - Core i3 6100T 3.2 GHz - 4 GB - 500 GB - LED 23"
Type Personal computer - all-in-one
Localisation Region: United Kingdom
Processor 1 x Intel Core i3 (6th Gen) 6100T / 3.2 GHz (Dual-Core)
Processor Socket LGA1151 Socket
Processor Main Features Hyper-Threading Technology
Cache Memory 3 MB
Cache Per Processor 3 MB
RAM 4 GB (installed) / 32 GB (max) DDR4 SDRAM - non-ECC
Storage Controller SATA (SATA 6Gb/s)
Hard Drive 1 x 500 GB - SATA 3Gb/s - 5400 rpm
Optical Storage No optical drive
Monitor 23" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
Graphics Controller Intel HD Graphics 530 Shared Video Memory (UMA)
Networking GigE
Power AC 120/230 V (50/60 Hz)
OS Provided Windows 10 Pro 64-bit Edition
Dimensions (WxDxH) 55.4 cm x 22.5 cm x 43.3 cm
Weight 8.62 kg
Environmental Standards Blue Angel
Manufacturer Warranty Limited warranty - 3 years - on-site
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu Esprimo X956/T...
£580.93
