Fujitsu fi-6400 Image Scanner (100ppm)
£5,247.54
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Fast, 100 ppm (simplex) / 200 ipm (duplex) scanning in monochrome or color
  • Great cost to performance ratio
  • Space-saving design with quiet operation and many environmental friendly qualities
  • Easy to use operator panel
  • Triple Ultrasonic Double Feed detection with Intelligent MultiFeed function and retain image feature
  • 500-page automatic document feeder with adjustable height hopper
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A3 (297 x 420 mm)
  • Interface: USB 2.0
  • Compatibility: PC
Product codes
For the paper-intensive back-office, the Fujitsu fi-6400 scanner digitizes tens of thousands of documents a day. With proven feed mechanics and high-quality image cleanup, the fi-6400 sustains a spectacular throughput, providing businesses with an exceptional ROI. As promised, Fujitsu has delivered a trusted production scanner in a quiet and compact space. To boost the efficiency of large volume scanning at centralized operations, up to 500 sheets can be loaded in the hopper at a time. Together with an impressive scanning speed of 100 ppm (color, A4 size, simplex, 200/300 dpi, landscape), maximum productivity can be achieved. The fi-6400 is capable of digitizing a variety of document types used in many scenarios from ultra-thin receipts to thick documents (20-209 g/m²). In addition, this scanner is equipped with a reliable "paper protection functions" to minimize the risk of documents being damaged even during high speed scanning. The Fujitsu fi-6400 scanner empowers scanner operators to provide efficient centralized batch scanning. The included suite of PaperStream IP, PaperStream Capture and Scanner Central Admin provides users with a powerful, efficient and easy-to-use image enhancement solution to get organizations up and scanning quickly and easily.
PaperStream IP - Automatically creates high quality images without manual adjustments - The scanner driver PaperStream IP, which provides TWAIN/ISIS support, automatically converts documents into exceptionally clean images, improves OCR even when scanning wrinkled/soiled documents or documents with backgrounds and eliminates the hassle of fine tuning scanner settings.
PaperStream Capture - Batch scanning, validate and confirm the document content - PaperStream Capture is an application for scanning and managing scanned images from Fujitsu's fi Series scanners. Adjusting scanning settings and performing batch scanning, are accomplished easily with PaperStream Capture's user-friendly interface. With the seamless linkage to the PaperStream IP driver, high quality image processing and batch scanning are performed simultaneously. With just a few easy settings, PaperStream Capture automates sorting and saving of scanned documents. The "Automatic Image Quality Checker" automatically highlights folded and damaged documents allowing effortless validation of scanned images.
Scanner Central Admin - Efficiently manage multiple scanners - Using the bundled Scanner Central Admin application, up to 1,000 scanners can be managed from one central location. In addition, the usage status is traced, so periodic replacement of consumables can be performed smoothly.
Product Description Fujitsu fi-6400 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type Dual CCD
Light Source White LED array
Max Supported Document Size A3 (297 x 420 mm)
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Interpolated Resolution 1200 dpi x 1200 dpi
Max Document Scan Speed 100 ppm (mono) / 100 ppm (colour)
Max Document Size 297 mm x 420 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 500 sheets
Duty Cycle 40000 scans per day
Power AC 120/230 V
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
Dimensions (WxDxH) 46 cm x 43 cm x 31 cm
Weight 32 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-6400 Image...
£5,247.54
