Fujitsu fi-6670 Document Scanner
Key features
  • Fast scanning - up to 90ppm / 180ipm in colour or monochrome, landscape
  • Ultrasonic double-feed detection with advanced control
  • Loaded with "intelligent" functions for more efficient scanning
  • Bundled with PaperStream IP and PaperStream Capture for enhanced image processing and batch scanning
Product codes
Transform your paper documents into useful electronic data in a flash with the intelligent scanning features of the Fujitsu fi-6670 production level scanner. Designed with outstanding paper handling, high scan speeds up to 90ppm / 180ipm and intelligent productivity enhancement features, the Fujitsu fi-6670 scanner delivers the automation and dependability needed for production scanning applications. The Fujitsu fi-6670's intelligent multi-feed function drastically improves the batch scanning process by allowing the ultrasonic double-feed detection sensor to be trained to ignore intentional overlapping documents, including photos, label stickers, or taped-on receipts. The Fujitsu fi-6670 color scanner comes additionally bundled with PaperStream IP and PaperStream Capture for enhanced batch processing and image enhancement.
True to Fujitsu's commitment to environmentally responsible manufacturing and design, the fi-6670 business scanner adheres to strict environmental regulations including Energy Star's energy consumption requirements and the EU's Reduction of Hazardous Substances and Volatile Organic Compounds.
Fujitsu fi-6670 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
CCD
Max Supported Document Size
ANSI B (Ledger) (279 x 432 mm)
Input Type
Grayscale / Color Depth
10-bit grey
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 90 ppm (colour)
Max Document Size
279 mm x 432 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
200 sheets
Duty Cycle
15000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits)
30 cm x 17 cm x 30 cm
17 kg
Environmental Standards
ENERGY STAR Qualified
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-6670 Docume...
