Fujitsu fi-6800 A3 Duplex Document Scanner with Paperstream
£9,803.32
Delivery:
Standard: 1-3 working days
Key features
  • A revolutionary, green design
  • Unrivaled performance and value for money
  • Hassle-free usability
  • Bundled with PaperStream IP and PaperStream Capture for enhanced image processing and batch scanning
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A3 (297 x 420 mm)
  • Interface: SCSI, USB 2.0
  • Compatibility: PC
Product codes
The fast and intuitive FUJITSU Image Scanner fi-6800 mid-volume scanner brings significant operating benefits to paper intensive organizations. A unique compact design provides users with a solution that is ready to improve productivity without delay. Rapid start up time, smooth paper flow and ease of use all contribute to an efficient end-to-end image capture process and powerful software ensures document preparation and post-scan procedures are minimized.
Automated routines deliver a performance bonus to document-hungry businesses when archiving records, satisfying compliance requirements and introducing ad hoc documents to workflows. The result is a robust scanner that reduces the total cost of ownership and provides a fast return on investment.
Convert large volumes of documents with speed and dependable throughput every day. The fi-6800 minimizes operator alerts through a host of automated functionalities to provide uninterrupted performance when processing large batches of documents.
Operators can manage mixed document batches efficiently when the physical characteristics of documents change within the batch. The fi-6800 handles different sized sheets from A8 to A3 and differences in materials such as when paper, card and plastic vary in weight and thickness - leaving the operator free to attend to parallel tasks without being distracted by avoidable misfeed alerts.
The bundled PaperStream IP driver takes the work out of image cleanup when scanning invoices, ID cards, receipts, forms, or any other day to day paperwork. PaperStream IP automatically improves the image quality, removes unwanted backgrounds, and optimizes your scanned images for optical character recognition. It is fast and easy to use. The latest innovation, Assisted Scan, allows users to replace poor images by visually selecting the image they lack rather than learning driver settings. If driver settings need to be adjusted for rare and difficult documents, a preview function allows scan operators to see their adjustments in real-time without time consuming re-scans. PaperStream IP works with both ISIS and TWAIN applications.
The bundled PaperStream Capture makes advanced capture with Fujitsu scanners easier than before. PaperStream Capture has a streamlined User Interface to reduce training time and increase productivity. Not only has FUJITSU provided users with the most common profiles used by customers - black and white, color, and auto-color - new profiles are easily created or modified through a wizard. FUJITSU has organized the release screen so that batches can easily be suspended or continued. PaperStream Capture is also integrated with PaperStream IP's assisted scanning for visual cleanup of documents. The reading of barcodes and patch codes make batch separation easy, improving document organization.
Product Description Fujitsu fi-6800 - document scanner - desktop - USB 2.0, SCSI
Device Type Document scanner - desktop
Interface Type USB 2.0, SCSI
Scan Element Type Dual CCD
Max Supported Document Size A3 (297 x 420 mm)
Input Type Colour
Grayscale / Color Depth 10-bit grey
Grayscale / Color Depth (External) 8-bit (256 grey levels)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 130 ppm (mono) / 130 ppm (colour)
Max Document Size 305 mm x 432 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 500 sheets
Duty Cycle 60000 scans per day
Power AC 120/230 V
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
Dimensions (WxDxH) 46 cm x 43 cm x 31 cm
Weight 32 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-6800 A3 Dup...
£9,803.32
