Fujitsu fi-7030 Document Scanner
£448.96
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Instant document capture; fast processing: 27 ppm / 54 ipm full speed
  • Entry-level professional document capture solution for public and commercial organisations
  • Includes newly developed high performance document capture solution ‘PaperStream Capture 1.5 licence’ for improved batch scanning efficiency
  • Includes PaperStream IP which prepares digitised data for OCR processing and connects with a TWAIN or ISIS interface
  • Includes an integrated bar code module that facilitates mixed batch scanning with automated processing
  • Compact and robust with reliable feeding mechanisms
Product codes
The fi-7030 is the ideal entry point to professional information capture. It is equipped with PaperStream Capture Version 1.5 that offers a new ergonomic, touch compatible user interface which improves efficiency and interactions across the entire enterprise capture process. The fi-7030 is based on PFU's proven superior image quality technology, combined with improved image processing and capture software, offering everything that users need to start their digital transformation journey.
The fi-7030 captures A4 documents at a speed of 27 double sided sheets per minute (portrait, color, 300 dpi) and can comfortably process mixed batches that can also include embossed cards, long paper scanning of up to 5 meters through the 50 page ADF is also possible as well as A3 documents utilizing an optional carrier sheet.
The scanner additionally makes use of an ultrasonic sensor that accurately detects multifeed errors where two or more sheets are fed through the scanner at once plus intelligent multifeed function that is designed for documents that intentionally feature paper attachments of defined sizes or locations such as sticky notes or photos. The scanner can automatically recognize the location of the attachment and will then exclude that zone from triggering alert conditions.
Should you be scanning mixed batches of differing thicknesses of documents then the "skew reducer" eliminates the risk of physical skew being carried over from one sheet in a mixed batch to the next ensuring that each document is captured with the utmost precision and simplicity. Multi-segmented pick rollers that rotate independently ensure that if a document goes through skewed then this will not affect the alignment of the next document.
The fi-7030 comes with Scanner Central Admin tools that includes functions that system administrators can use to manage the installation and operation of multiple scanners, monitor operating status and update drivers and software from one location. This ability dramatically reduces the cost and work that goes into setting up, operating and maintaining many scanners in an organization and also in expanding the scanner network to multiple locations.
The fi-7030 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture 1.5 introduces detailed scanning routine information next to related profile pictograms, facilitating the capture process and allowing users to choose between fully transparent in-depth details for experts, or simplified easy processing for general users. A new "browse view" functionality, which displays both thumbnails and previews on one screen, enables the user to confirm scanned images during scanning. This saves time when users validate, classify and verify data. Other highlights include the display of batch jobs in process for more transparency and an on-the-fly batch release process. Once users have scanned a batch they can verify the data, alternate orders, collect documents in a joint file, index and automatically release to local or distant repositories, feed workflows, business applications or ECM systems.
Fujitsu fi-7030 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
RGB LED array
Max Supported Document Size
216 x 355.6 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
27 ppm (mono) / 27 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
AC 120/230 V
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
29 cm x 14.6 cm x 13 cm
2.9 kg
Environmental Standards
ENERGY STAR Qualified
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-7030 Docume...
£448.96
