Fujitsu fi-7140 A4 Document Scanner
£517.83
11 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Outstanding paper feeding delivers reliable batch scanning regardless of the document condition
  • Reliable Skew Reducer even when scanning a mixed size batch
  • Compact design for fast scanning right at your desk
  • Automatically creates the most suitable high quality image data for OCR process
  • Bundled with PaperStream IP and PaperStream Capture, a TWAIN and ISIS scanner driver and document capture software application designed for enhanced image processing and instant batch scanning
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 355.6 mm
  • Interface: USB 2.0
  • Compatibility: PC
Product codes
Outstanding performance starts with reliable, compact hardware technology automatically supported by intuitive routines.
The sleek and compact 40 double sided pages per minute fi-7140 desktop ADF scanner from Fujitsu allows for merging paper document content with digitally born data. Enjoy the introduction of optimum quality from automated document capture and increase the breadth of document management related activities such as invoice and forms processing, archiving and workflow. Flexibly fit this document capture solution to existing and emerging tasks such as current mail delivery methods or addressing regulatory concerns.
Product Description Fujitsu fi-7140 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type Dual CCD
Light Source White LED array
Max Supported Document Size 216 x 355.6 mm
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 40 ppm (mono) / 40 ppm (colour)
Max Document Size 216 mm x 5588 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, plastic card
Document Feeder Type Automatic
Document Storage Capacity 80 sheets
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Ubuntu 16.04
Dimensions (WxDxH) 30 cm x 17 cm x 16.3 cm
Weight 4.2 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-7140 A4 Doc...
£517.83
