Fujitsu fi-7280 Document Scanner
£1,547.43
Delivery:
Standard: 1-3 working days
Key features
  • Scans A4 colour documents at 80 pages per minute or 160 images per minute at 300 dpi
  • Equipped with Intelligent Sonic Paper Protection function for improved paper feeding based on detecting irregular paper noise
  • Mixed batch scanning allows for instant processing of batches of mixed sizes and weights direct into existing workflows
  • Scanner Central Admin suite and LCD allow for instant monitoring and administering
  • Bundled with PaperStream IP and PaperStream Capture for seamless batch scanning and high quality image enhancement
  • Built in flatbed for the scanning of bound or delicate material
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 355.6 mm
  • Interface: USB 3.0
  • Compatibility: PC
Product codes
The fi-7280 document scanner from Fujitsu with ADF and flatbed is armed with a host of automated hardware and software based tools designed to make the job of scanning mixed batches of documents as seamless and hassle free as possible. Impressive scan speeds, industry leading paper protection mechanisms, status monitoring tools and bundled Fujitsu developed driver (PaperStream IP) and image enhancement software (PaperStream Capture) help ensure that the capture of your documents is done reliably and efficiently.
Product Description Fujitsu fi-7280 - document scanner - desktop - USB 3.0
Device Type Document scanner - desktop
Interface Type USB 3.0
Scan Element Type Triple CCD
Max Supported Document Size 216 x 355.6 mm
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 80 ppm (mono) / 80 ppm (colour)
Max Document Size 216 mm x 5588 mm
Automatic Duplexing Yes
Supported Document Type Plain paper
Document Feeder Type Automatic
Document Storage Capacity 80 sheets
Duty Cycle 6000 scans per day
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Ubuntu 16.04, Microsoft Windows Server 2016 (64-bit)
Dimensions (WxDxH) 30 cm x 57.7 cm x 23.4 cm
Weight 8.8 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-7280 Docume...
£1,547.43
