Fujitsu fi-7600 A4 Document Scanner
£3,549.27
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Instant processing performance at 100 ppm / 200 ipm (A4, landscape, colour, 200/300 dpi)
  • Mixed batch scanning – A8 to A3 from 20-413 g/m²
  • Folded documents up to A1 and longer
  • 300 sheet ADF
  • 30,000 document daily duty cycle
  • Paper Protect function which protects jam by detecting abnormalities in sound (iSOP: Intelligent Sonic Paper
  • Protection) and document length
  • 2x LCD Operator Panels so the scanner can be oriented for Left or Right handed scanner operators
  • Independent Side Guides for easily aligning mixed size document
  • Comes with PaperStream IP (TWAIN/ISIS) and PaperStream Capture; Fujitsu developed scanner driver and
  • Image enhancement plus batch capture software application
Product codes
With scanning speeds of 100 ppm/200 ipm (200/300 dpi), the fi-7600 greatly improves process efficiency. Large volumes of information can be captured from various media types, including thin paper, plastic cards, envelopes and long page documents.
The fi-7600 automatically adjusts to paper weights from 20-413 g/m². The straight paper path reduces the load on a document and assures reliable scanning regardless of the condition and type of a document. By simply sliding a lever to non-separation mode, you can easily scan thick and long documents folded in half, multi-layered document sets and envelopes.
Skew Reducer automatically handles sheets of paper in a stack individually, so that if one sheet is fed-in skewed, subsequent sheets are not forced into physical skew. This ensures that all information in the documents is captured correctly, even in batches with mixed document formats. The Paper Protection function monitors document movement and automatically stops feeding when any irregularities are detected.
The fi-7600 is equipped with an operation panel on both sides allowing for right and left handed use. The LCD on the operation panel reveals the scanner status at a glance and enables instant operation.
The Automatic Document Feeder's (ADF) independent side guides move to exactly the position required for each batch. The adjustable stacker side guides support neat alignment of processed documents.
The fi-7600 comes bundled with PaperStream IP, an integrated scanner driver and image enhancement module that is built on TWAIN/ISIS standards offering user friendly operability, intuitive high quality image creation and real time processing that will benefit post scan routines like OCR. PaperStream Capture enhances the document capture process from adjusting scanning settings to performing batch scanning, verifying data and releasing to directories, repositories or subsequent process routines. Users can complete data capture tasks easily with the extremely user-friendly graphical user interface (GUI). Moving scanned batches into a queue for later retrieval is possible as well.
Fujitsu fi-7600 - document scanner - desktop - USB 3.1 Gen 1
Document scanner - desktop
Interface Type
USB 3.1 Gen 1
Scan Element Type
Dual CCD
Light Source
White LED array
Additional Functions
Scan to SharePoint
Max Supported Document Size
304.8 x 431.8 mm
Input Type
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
100 ppm (mono) / 100 ppm (colour)
Max Document Size
304.8 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, plastic card, envelope, embossed card
Document Feeder Type
Automatic
Document Storage Capacity
300 sheets
Duty Cycle
30000 scans per day
AC 120/230 V
Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
23.6 cm x 43.2 cm x 21.4 cm
11 kg
Environmental Standards
ENERGY STAR Qualified
1 year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu fi-7600 A4 Doc...
£3,549.27
