The Fujitsu tablet LIFEBOOK T938 is a versatile 2 in 1 that meets the dynamic demands of today's mobile professionals. Its enterprise-grade security, lightweight and ultra-thin design with durable magnesium housing, enable you to be productive at all times. A simple flip of the super crisp, rotatable 13.3-inch Full HD display with pen and touch support is all it takes to switch between tablet and notebook mode.
Product Description | Fujitsu LIFEBOOK T938 - 13.3" - Core i7 8650U - 8 GB RAM - 512 GB SSD - UK | Product Type | Notebook - convertible | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (8th Gen) 8650U / 1.9 GHz (3.9 GHz) / 8 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 512 GB SSD SED, TCG Opal Encryption, NVMe | Optical Drive | No optical drive | Display | 13.3" LED backlight touchscreen 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Input Device | Digitizer, digital pen | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Features | Ambient light sensor, digital compass, gyro sensor, hall sensor, 3-axis accelerometer | Dockable | Yes | Security | Trusted Platform Module (TPM 2.0) Security Chip, smart card reader, palm vein sensor | Dimensions (WxDxH) | 31.8 cm x 22.4 cm x 1.98 cm | Weight | 1.3 kg | Localisation | Region: United Kingdom | Manufacturer Warranty | Limited warranty - 2 years - carry-in - availability: 9 hours a day / Monday-Friday |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8650U / 1.9 GHz |
Max Turbo Speed | 3.9 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Platform Technology | Intel vPro Technology |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2400 MHz / PC4-19200 |
Rated Speed | 2400 MHz |
Slots Qty | 1 |
Empty Slots | 0 |
Storage | |
Main Storage | 512 GB SSD - (M.2) PCIe - Self-Encrypting Drive, TCG Opal Encryption, NVM Express (NVMe) |
Display | |
Type | 13.3" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 330 cd/m² |
Features | Anti-glare, magnesium lid |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD (front) |
Resolution | 5 Megapixel (rear) |
Camera Features | LED indicator |
Sound | Stereo speakers, dual array microphone |
Codec | Realtek ALC255 |
Input | |
Type | Keyboard, digitizer, touchpad, digital pen |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Wacom Active ES technology |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 8265 |
Network Interface | Gigabit Ethernet |
Remote Management Protocol | DMI, CIM |
Features | Wake-on-LAN (WOL) |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 50 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19 V, 3.42 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , USB 3.1 Gen 1 , USB 3.1 Gen 1 (Anytime USB Charge) , USB-C 3.1 Gen 1 (Power Delivery) , VGA , HDMI , LAN , Dock |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Software | |
Software Included | Adobe Reader, Fujitsu Shock Sensor Utility, Fujitsu Display Manager, CyberLink Youcam, Power Saving Utility, Plugfree Network, Microsoft Office (30 days trial), DeskView Client, DeskView Instant BIOS Management, Workplace Protect, Fujitsu DeskUpdate, Windows 10 Pro 64-bit recovery DVD |
Miscellaneous | |
Integrated Options | Ambient light sensor, digital compass, gyro sensor, hall sensor, 3-axis accelerometer |
Dockable | Yes |
Features | Administrator password, system password, hard drive password, RapidCharge, BIOS Absolute Persistence, Preboot Execution Environment (PXE) support |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.3 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years - carry-in - availability: 9 hours a day / Monday-Friday |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% |
