Fujitsu N7100 Network Document Scanner
£1,128.32
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Fast scanning speeds of 25 pages per minute and true double-sided speeds of 50 images per minute in colour, greyscale or monochrome @ 300 dpi
  • 50 page document feeder
  • Large 8.4” touch screen high resolution (1,024 x 768 pixels) display
  • Scan to e-mail, folder/FTP, network fax or printer or Microsoft SharePoint Server Enterprise features *Limited version support for SharePoint*
  • Scanner Central Admin Server software
  • Job Menus based on individual user login to control scanning settings and destination(s)
  • High security to assist with compliance and regulation
  • SDK and optional third-party applications for integration with line of business systems
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 355.6 mm
  • Interface: Gigabit LAN
  • Compatibility: PC, Unix
Product codes
With the functionality of many devices, yet the simplicity of one, the N7100 network scanner contains the qualities organizations of all sizes desire to improve business processes.
A large size screen with integrated on-screen keyboard and PC functions are equipped in this compact network scanner. It can be used in the office or a teller window where space is limited. The user can perform scanning, data saving and transmission without the need to operate from a computer.
Scanning speed is consistent at 25 pages per minute (ppm) even when scanning full A4 color, double-sided, at 300dpi. N7100 is equipped with accurate and stable feeding mechanisms that support scanning from thin paper to thick paper, and plastic cards. Plastic ID cards and application forms can be scanned together easily at a teller window of banks or hospitals.
In order for the user not to feel any stress, the image processing after scanning is quick thanks to the enhanced CPU/memory. The time from the start of scanning to the finish including image processing (when the preview of the last scanned page appears) is 50% shorter than the previous model. For regular scanning routines, only one touch of the scan button is necessary which greatly improves the productivity.
The N7100 achieves high security on the premise that it is shared by multiple users. Not only verification before scanning, but also the encryption for paused scans and data deletion after scanning are performed automatically. Users can use the network scanner with peace of mind.
Administrators can customize the touch panel job menu and scan settings of N7100 to suit the work of a specific user or user group registered to the scanner. The user's application can be integrated to the scanner as add-in software using the exclusive SDK (for Windows). N7100 comes with an open USB port to connect a keyboard or other USB devices (except USB memory). N7100 can be customized to be a terminal exclusively for your operation.
The scanner driver PaperStream IP which supports TWAIN saves the hassle in fine adjusting the document for OCR processes. It automatically converts the images into exceptionally clean images, accelerating OCR even when scanning wrinkled/soiled document or documents with a background.
Advanced automated functions ensure N7100 digitizes your documents with remarkable precision and efficiency. Produce beautiful scans quickly with barely the need to lift a finger.
Product Description Fujitsu Network Scanner N7100 - document scanner - desktop - Gigabit LAN
Device Type Document scanner - desktop
Interface Type Gigabit LAN
Scan Element Type Dual CIS
Light Source RGB LED array
Additional Functions Email, fax, scan to print, scan to network share, scan to FTP
Max Supported Document Size 216 x 355.6 mm
Input Type Colour
Grayscale / Color Depth (External) 8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 25 ppm (mono) / 25 ppm (colour)
Max Document Size 216 mm x 355.6 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, business card, envelope, post card
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Duty Cycle 400 scans per day
Power AC 120/230 V
Dimensions (WxDxH) 30 cm x 23.2 cm x 17.2 cm
Weight 6 kg
Environmental Standards ENERGY STAR Qualified
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu N7100 Network...
£1,128.32
