Fujitsu P24-8 TE 23.8" 1920x1080 5ms VGA DVI DP LED IPS...
Fujitsu P24-8 TE 23.8" 1920x1080 5ms VGA DVI DP LED IPS Monitor
£245.01
Delivery:
Key features
  • Call and status indicator
  • Presence sensor with PC security solution
  • In-Plane Switching (IPS) technology
  • Low blue light mode
Product codes
Fujitsu P24-8 TE Pro display is the perfect choice for demanding and tidy workplaces. Besides thin bezels and cable guide it also boasts unique features, such as USB support in standby and the presence sensor to detect the user's absence. With the call indicator you are prepared for modern applications.
Fujitsu P24-8 TE Pro - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class A
Energy Consumption per Year
32 kWh
Power Consumption (On mode)
19 W
USB 3.1 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Marble grey
55.3 cm x 22.94 cm x 34.7 cm
5.6 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu P24-8 TE 23.8"...
£245.01
