Fujitsu P24-8 TE 23.8" 1920x1080 5ms VGA DVI DP LED IPS...
Fujitsu P24-8 TE 23.8" 1920x1080 5ms VGA DVI DP LED IPS Monitor
£249.07
Delivery:
Key features
  • Call and status indicator
  • Presence sensor with PC security solution
  • In-Plane Switching (IPS) technology
  • Low blue light mode
  • Diagonal Size: 23.8in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
Fujitsu P24-8 TE Pro display is the perfect choice for demanding and tidy workplaces. Besides thin bezels and cable guide it also boasts unique features, such as USB support in standby and the presence sensor to detect the user's absence. With the call indicator you are prepared for modern applications.
Product Description Fujitsu P24-8 TE Pro - LED monitor - Full HD (1080p) - 23.8"
Device Type LED-backlit LCD monitor - 23.8"
Energy Class Class A
Energy Consumption per Year 32 kWh
Power Consumption (On mode) 19 W
Features USB 3.1 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080
Pixel Pitch 0.2745 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI-D, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Marble grey
Dimensions (WxDxH) - with stand 55.3 cm x 22.94 cm x 34.7 cm
Weight 5.6 kg
Localisation United Kingdom
Environmental Standards TCO Certified Displays 7, ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, BSMI, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, cTUVus, KC, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu P24-8 TE 23.8"...
£249.07
