Fujitsu P24-8 WS Pro 24.1" 1920x1200 5ms VGA DVI HDMI DP...
Fujitsu P24-8 WS Pro 24.1" 1920x1200 5ms VGA DVI HDMI DP LED Monitor
Key features
  • In-Plane Switching (IPS) technology with an ultra wide viewing angle of 178° and 100% coverage sRGB color space
  • LED backlight technology and high precision color calibration
  • Optimized working position - with ergonomic stand featuring height adjust, 340° swivel, comfortable 35° rear tilt and low position of picture over desk
  • Best choice for multi monitor environments due to DisplayPort 1.2 and DisplayPort output for daisy chaining. Bidirectional 90° rotation with Auto Pivot sensor
  • Clinical review applications are suported by DICOM grayscale standard compatible preset
  • Ready for remote inventory collection and configuration tasks with DisplayView Manageability tools
  • Integrated ultra-fast USB 3.0 hub, available even in standby mode (e.g. for incoming calls via optional USB headset)
Product codes
The FUJITSU P24-8 WS Pro display provides outstanding picture performance thanks to cutting edge panel technology. It is the perfect choice for CAD and document management applications with request for 1,200 lines. It also boasts unique and innovative features such as the patent applied Presence Sensor technology and USB support during standby.
Minimized frame on three sides of the screen ensure future oriented, space-saving design. The gap between two panels is almost eliminated - only 6.7 mm border around the active picture area on top and the sides.
Product Description Fujitsu P24-8 WS Pro - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A+
Energy Consumption per Year 28 kWh
Power Consumption (On mode) 19 W
Features USB 3.1 Gen 1 hub
Panel Type IPS
Aspect Ratio 16:10
Native Resolution WUXGA 1920 x 1200
Pixel Pitch 0.27 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI-D, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Matte black
Dimensions (WxDxH) - with stand 53.2 cm x 22.7 cm x 38.9 cm
Weight 7 kg
Localisation United Kingdom
Environmental Standards ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, VCCI, cUL, EN 60950, SASO, DDC/CI, RoHS, WEEE, S Mark, Directive 2004/108/EEC, EAC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification, ISO 9241-307 Class 1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu P24-8 WS Pro 2...
