Fujitsu P27-8 TS 27" 2560x1440 5ms VGA DVI HDMI DP LED I...
Fujitsu P27-8 TS 27" 2560x1440 5ms VGA DVI HDMI DP LED IPS Monitor
£529.27
Delivery:
Key features
  • In-Plane Switching (IPS) technology
  • Presence Sensor with PC security solution
  • Auto brightness control (ABC)
Product codes
If you're a pixel, color and performance-hungry professional, using demanding applications, the Fujitsu P27-8 TS Pro display is the perfect choice. The display provides outstanding picture performance thanks to advanced panel technology and multiple pixels. It also boasts unique and innovative features, such as Presence Sensor technology and USB support during standby.
Fujitsu P27-8 TS Pro - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
24 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI, 2xDisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Matte black
61.3 cm x 22.7 cm x 39.6 cm
7.61 kg
United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV GS, VCCI, BSMI, GOST, cUL, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, KC, Directive 2004/108/EEC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TCO Displays 7.0, TUV Rheinland Flicker Free Certification
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu P27-8 TS 27" 2...
£529.27
