Fujitsu P27-8 TS 27" 2560x1440 5ms VGA DVI HDMI DP LED I...
Fujitsu P27-8 TS 27" 2560x1440 5ms VGA DVI HDMI DP LED IPS Monitor
£454.42
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • In-Plane Switching (IPS) technology
  • Presence Sensor with PC security solution
  • Auto brightness control (ABC)
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
Bundle deals (1)
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £457.91
Save £1.50
If you're a pixel, color and performance-hungry professional, using demanding applications, the Fujitsu P27-8 TS Pro display is the perfect choice. The display provides outstanding picture performance thanks to advanced panel technology and multiple pixels. It also boasts unique and innovative features, such as Presence Sensor technology and USB support during standby.
Product Description Fujitsu P27-8 TS Pro - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class A
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 24 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 2560 x 1440
Pixel Pitch 0.233 mm
Brightness 350 cd/m²
Contrast Ratio 1000:1 / 20000000:1 (dynamic)
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors HDMI, DVI, 2xDisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Screen Coating Anti-glare, 3H Hard Coating
Colour Matte black
Dimensions (WxDxH) - with stand 61.3 cm x 22.7 cm x 39.6 cm
Weight 7.61 kg
Localisation United Kingdom
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards FCC Class B certified, TUV GS, VCCI, BSMI, GOST, cUL, EN 60950, SASO, CCC, RoHS, ISO 9241-307, WEEE, S Mark, KC, Directive 2004/108/EEC, RCM, VESA MIS-D 100 C, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu P27-8 TS 27" 2...
£454.42
