Fujitsu ScanSnap iX100 Mobile Wireless Document Scanner
£201.37
Delivery:
Key features
  • Scan everyday documents at 5 seconds per A4 page
  • Scan wirelessly to mobile and desktop devices, cloud services and office applications
  • Powerful GI processor for outstanding results
  • Cordless operation with Lithium-ion battery
  • Charges via micro USB socket
  • Up to 260 scans per full charge
  • Choice of paper paths for when space is tight or document type dictates
  • Scan two or more small documents such as business cards simultaneously
  • Scans A3 documents: Automatically pairs A4 pages with overlapping content
  • Productive Win/Mac OS software bundle includes Quick Menu, ScanSnap Organizer, CardMinder and ABBYY FineReader
  • Type: Sheetfed scanner
  • Form Factor: Portable
  • Max Paper Size: 216 x 863 mm
  • Interface: USB 2.0, Wi-Fi
  • Compatibility: Mac, PC
Product codes
The cross platform compatible ScanSnap iX100 brings the power and intuitiveness of the ScanSnap range of models to a compact and totally wireless format. The light-weight iX100 comes with a USB rechargeable Lithium-ion battery that is capable of up to 260 A4 scans on a full charge. Combined with an ability to scan either via a wireless network to PC workstations or mobile devices, this ScanSnap delivers a true "scan anytime scan anywhere.
The ScanSnap iX100 can automatically detect Wi-Fi networks at home, in the office or on the go, it is only needed to be set up once after which any regularly visited network environment will be automatically detected. Alternatively with Direct Connect mode it is possible to scan wirelessly beyond an infrastructure network, simply download the ScanSnap Connect Application free of charge from the official application distribution services and then scan, save and distribute documents directly to an iPad, iPhone or Android device.
A multitude of everyday documents can be seamlessly processed by the iX100 at a speedy 5 seconds, whether it be business cards or receipts (check out the impressive dual scan functionality that allows you to scan small documents simultaneously), photos, thicker items like postcards, bills, everyday A4 documents or even A3 documents. Scan both sides of a folded A3 document one after the other and if an adjoining pattern is detected the bundled software will automatically join the 2 page images together.
The iX100 will automatically detect and scan in black and white or color, will recognize the size of each document and scan accordingly, will detect and correct for skew and will show images in their proper orientation with blank pages removed. All these automatic functions help ensure that the first scan is the best scan and minimize operator involvement.
The iX100 can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as SnapScan folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the SnapScan Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
Product Description Fujitsu ScanSnap iX100 - sheetfed scanner - portable - USB 2.0, Wi-Fi
Device Type Sheetfed scanner - portable
Interface Type USB 2.0, Wi-Fi
Scan Element Type Contact Image Sensor (CIS)
Light Source RGB LED array
Additional Functions Scan to cloud, scan to smart devices
Max Supported Document Size 216 x 863 mm
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Scan Speed 5 sec / scan
Max Document Size 216 mm x 863 mm
Supported Document Type Plain paper, business card, post card
Document Feeder Type Manual
Battery Lithium Ion
System Requirements Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple MacOS X 10.12
Dimensions (WxDxH) 27.3 cm x 4.75 cm x 3.6 cm
Weight 400 g
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu ScanSnap iX100...
£201.37
