Fujitsu ScanSnap iX1500 Document Scanner
£347.16
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Effortlessly scan your documents, invoices, receipts and business cards to PDF, Searchable PDF, JPEG and many editable formats including Microsoft Excel and Word
  • 4.3” Touchscreen and new ScanSnap Home software make it easy for you to use and share ScanSnap with your co-workers, friends or family (Includes licenses for up to 4 users)
  • ScanSnap Manager is now compatible with the iX1500
  • Saves you time by automatically detecting paper sizes, document types, deleting blank pages, cropping and rotating your scanned images
  • Intelligent automatic file-naming of your scanned documents that learns from keywords in your documents and edits that you have made
  • Scan via USB to PC or Mac or wirelessly to PC, Mac, iOS, Android devices and seamlessly sync your documents with your favourite cloud storage services
  • With a Wi-Fi connection, you can scan straight from the ScanSnap to the cloud without your PC, Mac, iOS or Android device
  • Automatic document feeder holds up to 50 sheets of A4 (80 gsm) paper
  • Scans both sides of documents simultaneously at up to 30 pages per minute / 60 images per minute
  • Supports standard paper sizes A4, A5, A6, B5, B6, Business Card, Post Card, Letter, Legal, Custom Sizes (50.8 mm x 50.8 mm - 216 mm x 360 mm) and Long Paper Scanning at up to 216 mm x 863 mm
  • Scans A3, B4, Double Letter, Photographs and Postcards with optional Carrier Sheets and Photo Carrier sheets
  • LED light source and advanced Image Quality features provide clear, crisp and sharp images
  • Stores up to 30 user profiles for sharing your ScanSnap with your co-workers, friends or family
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: 216 x 863 mm
  • Interface: USB 3.1 Gen 1, Wi-Fi
  • Compatibility: Mac, PC
Product codes
Discover the smarter way to work, using the ScanSnap iX1500. The iX1500’s 4.3-inch LCD touchscreen turns the old way of scanning on its head; instead of scanning a document and choosing what you want to do with it each time, now, after your first simple set-up, you can forget all about it. It also allows multiple users to each personalize the interface with their own set of large, color-coded buttons for the functions they use the most. The all-new ScanSnap Home software enables you to preview, tag, search and retrieve any document easily. ScanSnap Home also uses the text on your scans – such as the shop and company name – to recommend file names by learning and adapting to how you work! ScanSnap Cloud can send them straight to one of up to four different cloud storage locations and is smart enough to recognize which one depending on the document type; photos, receipts, business cards or documents. That means instant sharing with colleagues, friends and family. The reliability of its market leading feed technology and handy receipt guide means the iX1500 makes light work of both large and small items – from A3 documents down to ID cards or receipts. Boot up and be ready to go straight away thanks to the iX1500’s fast start-up – with the touch of just one button, you’ll be scanning within seconds, just open the cover and the ScanSnap iX1500 is ready to go. The ScanSnap iX500 has a speed of 30 double-sided sheets per minute, you’ll be done in no time at all – that means more time to get on with what really matters. The iX500 can be shared out of the box with up to 4 family members or colleagues; even more with additional licenses. Connect the iX1500 directly and instantly to your computer or smart device at home or in your office: from a computer you can utilise either USB, Wi-Fi with access point connect mode, or WiFi direct connect mode and from a smart device you can use either of the two WiFi mode options.
Product Description Fujitsu ScanSnap iX1500 - document scanner - desktop - Wi-Fi, USB 3.1 Gen 1
Device Type Document scanner - desktop
Interface Type Wi-Fi, USB 3.1 Gen 1
Scanning Sensor Type Dual CIS
Light Source RGB LED array
Max Supported Document Size 216 x 863 mm
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 30 ppm (mono) / 30 ppm (colour)
Max Document Size 216 mm x 863 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, plastic card, receipts
Document Feeder Type Automatic
Document Storage Capacity 50 sheets
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows 7 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Apple macOS 10.12, Apple macOS 10.13, Apple macOS Mojave 10.14
Dimensions (WxDxH) 29.2 cm x 16.1 cm x 15.2 cm
Weight 3.4 kg
Environmental Standards ENERGY STAR Qualified
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu ScanSnap iX150...
£347.16
