Fujitsu ScanSnap S1100i Document Scanner
£150.67
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Truly mobile scanning solution for Windows and Mac
  • Create a searchable PDF file with the touch of a button
  • Scan paper as small as an inch up to 863 mm long
  • Scan to an editable Word and Excel file
  • Create searchable keywords with a highlighter
  • Business card scanning software
  • Supports scanning a plastic ID card
  • Cross-platform compatibility for PC and Mac
  • USB powered
  • Type: Sheetfed scanner
  • Form Factor: Portable
  • Max Paper Size: 216 x 863 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
The ScanSnap S100i Mobile Scanner for PC and Mac takes document scanning just about anywhere! At just 350g, the ScanSnap S100i is the lightweight companion for front-side document scanning at home or on the road. Whether scanning receipts, contracts, recipes, or plastic cards, ScanSnap takes scanning beyond the desktop and into your world.
Scan at speeds that won't slow you down. The paperwork that you pick-up along the way, can go away quickly. Scan a color, A4 sheet in speeds of 8 pages per minute which is roughly 7.5 seconds per page. Business cards and receipts are even faster, and with Continuous Feed Detection (CFD), just insert the next page, ScanSnap takes the paper in and the effort out.
The S100i supports wireless scanning to iPad, iPhone, Android and Kindle devices for convenient viewing via the mobile app ScanSnap Connect Application.
TheS100i can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as ScanSnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
Product Description Fujitsu ScanSnap S1100i - sheetfed scanner - portable - USB 2.0
Device Type Sheetfed scanner - portable
Interface Type USB 2.0
Scan Element Type Contact Image Sensor (CIS)
Light Source RGB LED array
Additional Functions Scan to cloud, scan to smart devices, scan to file
Max Supported Document Size 216 x 863 mm
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Max Document Size 216 mm x 863 mm
Supported Document Type Plain paper, business card
Document Feeder Type Manual
System Requirements Microsoft Windows Vista (32/64 bits) SP2 or later, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple MacOS X 10.12
Dimensions (WxDxH) 27.3 cm x 4.75 cm x 3.4 cm
Weight 350 g
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu ScanSnap S1100...
£150.67
