Fujitsu ScanSnap S1300i
£210.50
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy to use "one touch" scanning
  • Double-sided color documents of A4 or letter size can be scanned
  • Compact, lightweight and portable
  • Scan up to 12 double-sided pages per minute
  • Holds up to 10 pages in the automatic document feeder
  • Cross-platform compatibility for PC and Mac
  • One button searchable PDF creation, PDF, and JPEG
  • Create searchable keywords from highlighter text
  • Ideal for mobile and stationary use in the office
  • Supports capturing documents for e-mail, printing and for use with Microsoft Word and Excel
  • ScanSnap Organizer PDF management and search software
  • CardMinder Business Card scanning software
  • ABBYY FineReader for ScanSnap Top-class OCR engine
  • Scan to Microsoft SharePoint Connector for Windows and Mac OS
  • Scan to iPad, iPhone, Android and Kindle devices
  • Scan to cloud services such as Dropbox, Evernote, Google Docs and SugarSync
  • Utilise ScanSnap Folder to scan into your preferred application when no scan interface available
  • Type: Document scanner
  • Form Factor: Portable
  • Max Paper Size: 216 x 863 mm
  • Interface: USB 2.0
  • Compatibility: Mac, PC
Product codes
At nearly half the size of a sheet of paper, the ScanSnap S1300i is built for convenience and ease of use, a one button approach allows for scanning of multi-page double-sided documents whether at the desk or on the road. Stack up to 10 pages into the automatic document feeder (ADF) and press the blue button.
ScanSnap S1300i scans both sides of each page at up to 12 pages per minute directly to PDF, searchable PDF, JPEG, or to office applications like Word or Excel. The ScanSnap S1300i automatically recognizes the size of each document, detects and corrects for skew, and shows images in their proper orientation. You can even choose to have blank pages automatically removed.
ScanSnap S1300i comes with an AC Adapter but for added mobile convenience, the ScanSnap S1300i can be powered though the computer's USB ports when an AC power source is not available.
The S1300i supports wireless scanning to iPad, iPhone, Android and Kindle devices for convenient viewing via the mobile app ScanSnap Connect Application.
The S1300i can link to cloud services Dropbox, Evernote, Google Docs, Salesforce CRM and SharePoint Online (for Windows). It also brings some additional cloud syncing functions: Scan to SugarSync and Scan to Salesforce Chatter as well as Scansnap folder for Win OS only where you can scan into your preferred cloud service when no scan interface is available through the import capability.
With the bundled ScanSnap Sync built into ScanSnap Organizer software and the ScanSnap Connect app, captured documents can be automatically synchronized with all your devices through Dropbox, Google Drive or Microsoft OneDrive.
The bundled ScanSnap Receipt software allows you to easily scan and extract information from your receipts, and even export the data for tax filing.
Product Description Fujitsu ScanSnap S1300i - document scanner - portable - USB 2.0
Device Type Document scanner - portable
Interface Type USB 2.0
Scan Element Type Contact Image Sensor (CIS)
Max Supported Document Size 216 x 863 mm
Input Type Colour
Optical Resolution 600 dpi x 600 dpi
Max Document Scan Speed 12 ppm (mono) / 12 ppm (colour)
Max Document Size 216 mm x 863 mm
Automatic Duplexing Yes
Document Feeder Type Automatic
Document Storage Capacity 10 sheets
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 (32/64 bits), Apple MacOS X 10.8, Windows 8.1 (32/64 bits), Apple MacOS X 10.9, Apple MacOS X 10.10, Windows 10 (32/64 bits), Apple MacOS X 10.11, Apple MacOS X 10.12
Dimensions (WxDxH) 28.4 cm x 9.9 cm x 7.7 cm
Weight 1.4 kg
Manufacturer Warranty 1 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£210.50
