Fujitsu SP-1425 A4 Duplex Document Scanner
£309.48
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Versatile: entry point into professional document management
  • Resourceful: purpose built with impressive software suite for efficiency gains
  • Reliable: intuitively and dependably converts physical documents to digital format
  • Convenient: simple and easy to use design, ideal for desktop placement. In-built flatbed for scanning of delicate or bound documents
  • Bundled with PaperStream IP for high quality image enhancement and PaperStream Capture Lite (download only) an essential capture tool
  • Bundled with Presto! PageManager which offers further possibilities for the enhancement, conversion, collaboration and organisation of your files
  • Type: Document scanner
  • Form Factor: Desktop
  • Max Paper Size: A4 (210 x 297 mm)
  • Interface: USB 2.0
  • Compatibility: PC
Product codes
Evolve from your physical to electronic documents with digital ease with the 25 double sided pages per minute SP-1425 scanner with flatbed and create one single source reference for all your data by merging these with your digitally born documents. Gain the business advantages of working with more convenient, flexible and secure digital images using simple push button routines, the SP-1425 features a simple operation panel with only 2 buttons (Scan / Stop and Power) as well as software enabled push button management. Bundled with a host of efficient document scanning software for higher productivity: PaperStream IP - Automatically creates the most suitable image data for hassle-free scanning, PaperStream Capture Lite (download only) an essential capture tool, ABBYY FineReader Sprint - Create searchable files from your paper documents, allowing you at a later date to find your information easier and Presto! PageManager - Making it easy to scan, share, and organize your documents and files. Turn your paper into organized digital documents.
Product Description Fujitsu SP-1425 - document scanner - desktop - USB 2.0
Device Type Document scanner - desktop
Interface Type USB 2.0
Scan Element Type Dual CIS
Light Source RGB LED
Max Supported Document Size A4 (210 x 297 mm)
Input Type Colour
Grayscale / Color Depth 8-bit (256 colours) / 24-bit (16.7 million colours)
Optical Resolution 600 dpi x 600 dpi
Interpolated Resolution 1200 dpi x 1200 dpi
Max Document Scan Speed 25 ppm (mono) / 25 ppm (colour)
Max Document Size 216 mm x 3048 mm
Automatic Duplexing Yes
Supported Document Type Plain paper, embossed card
Document Feeder Type Manual, automatic
Document Storage Capacity 50 sheets
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Microsoft Windows Server 2008 R2 (64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 (64-bit), Windows 10 (32/64 bits), Microsoft Windows Server 2016 (64-bit)
Dimensions (WxDxH) 45.4 cm x 33.1 cm x 12.9 cm
Weight 4.3 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Fujitsu SP-1425 A4 Dup...
£309.48
