Gigabyte AMD Radeon R5 230 625MHz 1GB PCI-Express 3.0 HDMI LP
Key features
  • Ultra Durable 2
  • Gold plated HDMI
  • OC GURU II
Product codes
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. Gigabyte is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, Gigabyte Ultra Durable 2 edition graphics card now features a sophisticated layout topology. This state-of-the-art power design from Gigabyte delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Gigabyte GV-R523D3-1GL (rev. 1.1) - graphics card - Radeon R5 230 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.1 x16
Graphics Engine
AMD Radeon R5 230
1 GB DDR3
Core Clock
625 MHz
Effective Memory Clock
1.066 GHz
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
DVI-D (dual link) , HDMI , VGA
API Supported
DirectX 11, OpenGL 4.1
2.4 cm x 18.4 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte AMD Radeon R5...
