Gigabyte AMD Radeon RX 550 D5 2GB PCIe3.0 Graphics Card
£126.96
Delivery:
Key features
  • Unique blade fan design
  • 3D active fan
  • Durable components
  • Smooth and crisp visual
  • Graphics Processor Manufacturer: AMD
  • Graphics Processor: AMD Radeon RX 550
  • Interface: PCI Express 3.0 x16
  • Memory Size: 2GB, 2GB
Product codes
Product Description Gigabyte Radeon RX 550 D5 2G - graphics card - Radeon RX 550 - 2 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine AMD Radeon RX 550
Memory 2 GB GDDR5
Core Clock 1195 MHz
Effective Memory Clock 7 GHz
Memory Interface 128-bit
Max Resolution 7680 x 4320
Max Resolution Details DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported 3
Interfaces DVI-D (dual link) , HDMI , DisplayPort
API Supported DirectX 12, OpenGL 4.5
Dimensions (WxDxH) 2.92 cm x 17 cm x 11.46 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte AMD Radeon RX...
£126.96
