Gigabyte GA-B250N-Phoenix WIFI LGA1151 Intel B250 DDR4 ITX
Key features
  • Fast USB 3.1 solution
  • Faster and better coverage with 802.11ac Wi-Fi
  • Fast onboard storage
  • Ambient LED
  • High-quality onboard audio design
  • DualBIOS design
Product codes
  • Supports 7th/6th Generation Intel® Core™ Processors.
  • Dual Channel Non-ECC Unbuffered DDR4, 2 DIMMs.
  • Fast USB 3.1 Gen 2 with USB Type-C™ and Type-A.
  • 802.11ac Dual Band 867Mbps wireless supports MU-MIMO and BT4.2.
  • Intel® GbE LAN with cFosSpeed Internet Accelerator Software.
  • RGB FUSION LED Light Show design.
  • Ultra-Fast M.2 with PCIe Gen3 x4 & SATA interface.
  • Smart Fan 5 features Multiple Temperature Sensors and Hybrid Fan Headers.
  • GIGABYTE UEFI DualBIOS™.
  • APP Center Including Cloud Station™ Utility.
RGB Fusion: Set the Colour that Matches Your Style
GIGABYTE's 200 series motherboards boast the most advanced LED system in the market today. With more customizability than ever and a convenient and intuitive UI thanks to the RGB Fusion App, you’ll have a blast making your GIGABYTE your own. LED enthusiasts now have even more options with the ability to customize multiple zones independently. For a more functional use, the bright and vibrant LEDs can be configured to display the PC’s temperature or load. For even more LED goodness RGBW strips are now supported for more true and vibrant whites.
Multi-Zone Light Show Design
  • 16.8M RGB Colours.
  • 2 Programmable Sections.
  • 7 Different Lighting Effects .
  • 1 RGBW Light Strip Pin Header.
  • Accent LED with Interchangeable Overlay.
  • Advanced Mode for Extreme Customizability.
Lighting zone, programmable sections, wave mode may vary by model.
Lighting Effects:
  • Pulse.
  • Music.
  • Static.
  • Flash.
  • Colour Cycle.
  • Intelligent.
Supports RGBW & -UV Light Strips: Independently Programmable On-board Pin Header for RGBW/-UV LED Strips
Not bright enough? You can install standard 12V external RGB, RGBW or RGB/UV light strips on the RGBW pin header and control its colour from the RGB Fusion software. Using a RGBW light strip with a dedicated white LED, users will experience brighter and more vibrant shades of colours.
When using RGB/UV LED strips, users can give their systems a fluorescent glow with the use of UV reactive liquid, neon braided cables, and acrylic paint for a wicked-looking gaming PC.
No need to worry when choosing light strips as AORUS motherboards support a wide variety of RGBW/-UV light strips on the market thanks to the RGB Fusion software that allows users to redefine the pin location for the R/G/B Signal.
Gigabyte GA-B250N Phoenix-WIFI - motherboard - mini ITX - LGA1151 Socket - B250
Motherboard - mini ITX
Chipset Type
Intel B250 Express
Processor Socket
1 x LGA1151 Socket
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4
Storage Ports
4 x SATA-600, 1 x M.2
USB / FireWire Ports
USB 3.0, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C + 1 x USB 3.1 + 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GA-B250N-Phoe...
