Gigabyte GA-H110M-S2H Intel H110 S1151 DDR4 PCIe3.0 USB3.0 mi...
Gigabyte GA-H110M-S2H Intel H110 S1151 DDR4 PCIe3.0 USB3.0 microATX
£55.05
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Supports 6th generation Intel Core processor
  • Dual channel DDR4, 2 DIMMs
  • 8-channel HD audio with high quality audio capacitors
  • Audio Noise Guard with LED trace path lighting
  • HDMI 1.4, DVI-D, D-sub ports for multiple display
  • Realtek GbE LAN with cFosSpeed Internet accelerator software
  • GIGABYTE APP Center, simple and easy use
  • Support Intel Small Business Basics
  • Processor Socket: LGA1151 Socket
  • Chipset: Intel H110 Express
  • Graphics: Graphics adapter (CPU required)
  • Form Factor: Micro ATX
  • Memory Support: DDR4 SDRAM
Product codes
GIGABYTE 100 series motherboards support the latest 6th Generation Intel Core processors, a 14nm desktop CPU which features improved performance, power efficiency and support for DDR4 memory, bringing cutting edge features and ultimate performance to your next PC build.
Realtek GbE LAN features cFosSpeed, a network traffic management application which helps to improve network latency, maintain low ping times to delivery better responsiveness in a crowded LAN environments. Realtek GbE consumes significant less power when it's in idle state in comparison with others.
With superfast transfer rates of up to 5 Gbps, users are able to experience an almost a 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users legacy USB 2.0 devices will still work.
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated Intel HD Graphics via HDMI.
Product Description Gigabyte GA-H110M-S2H - 1.0 - motherboard - micro ATX - LGA1151 Socket - H110
Product Type Motherboard - micro ATX
Chipset Type Intel H110 Express
Processor Socket 1 x LGA1151 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size 32 GB
RAM Supported 2 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports 4 x SATA-600
USB / FireWire Ports USB 3.0 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
Max Allocated RAM Size 512 MB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GA-H110M-S2H...
£55.05
