Gigabyte GA-Z270N-WIFI LGA1151 Intel Z270 DDR4 ITX
Key features
  • Supports 7th/6th generation Intel Core processors
  • Dual Channel Non-ECC Unbuffered DDR4, 2 DIMMs
  • Supports PCIe x16 slot bifurcation in 2x8 mode by riser card
  • Intel USB 3.1 Gen 1 with USB Type-C
  • Intel optane memory ready
  • Ultra-fast M.2 with PCIe Gen3 x4 & SATA interface
  • ALC1220 120 dB SNR HD audio with smart headphone amp
  • 802.11ac dual band 867 Mbps wireless supports MU-MIMO and BT4.2
  • Smart fan 5 features multiple temperature sensors and hybrid fan headers
  • Ultra durable metal shielding over PCIe slots
Product codes
Smart Fan 5
With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and Voltage mode fans have been introduced to make the motherboard more liquid cooling friendly.
  • 2 Fan Pin Headers.
  • 4 Temperature Sensors.
  • All Fan Pin Headers Upgraded to Hybrid Fan Headers.
  • Supports High Current Fans up to 24W (2Ax12V) with Over-Current Protection.
  • Intuitive UI for Fan Control.
All Hybrid Fan Pin Headers
  • Hybrid Fan Headers detect whether the cooling device uses PWM or Voltage mode and automatically switches settings accordingly.
  • Supports up to 2 amps with built-in overcurrent protection—a must for high-end high current fans.
Gigabyte GA-Z270N-WIFI - 1.0 - motherboard - mini ITX - LGA1151 Socket - Z270
Motherboard - mini ITX
Chipset Type
Intel Z270 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7 (supports 6th and 7th Generation Intel Core i3 / i5 / i7 / Pentium / Celeron)
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen1 1 x USB-C Gen 1 + 4 x USB 3.1 Gen 1 + (2 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Bluetooth, 2 x Gigabit Ethernet, 802.11a/b/g/n/ac
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GA-Z270N-WIFI...
