Gigabyte GeForce GT 730 902MHz 2GB GDDR5 PCI-Express 2.0 16 HDMI
Key features
  • Powered by NVIDIA GeForce
  • Integrated with the first GDDR5 memory and 64-bit memory interface
  • Features Dual-Link DVI-D/HDMI/D-Sub
  • Support PCI Express 2.0 x8 bus interface
Product codes
Using high quality components on graphics cards is the key factor for having a long lasting, stable and reliable product. GIGABYTE is again setting a new standard by using ferrite core chokes, low RDS (on) MOSFET and lower ESR solid capacitors, providing the stability and reliability from their high-end graphics solution. In addition, GIGABYTE Ultra Durable 2 Edition graphics card features a sophisticated layout topology. This state-of-the-art power design from GIGABYTE delivers the ideal integration of thermal, electric characteristics, digital signals, power circuitry and optimum placement of components for enhanced graphics performance.
Gigabyte GV-N730D5-2GI - graphics card - GF GT 730 - 2 GB
Graphics card
Bus Type
PCI Express 2.0 x8
Graphics Engine
NVIDIA GeForce GT 730
2 GB GDDR5
Core Clock
902 MHz
Effective Memory Clock
5 GHz
Memory Interface
64-bit
Max Resolution
4096 x 2160
Max Monitors Supported
3
DVI-D (dual link) , VGA , HDMI
API Supported
DirectX 11.2, OpenGL 4.4
3 cm x 17.7 cm x 12 cm
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GeForce GT 73...
