Gigabyte GeForce GTX 1050 Ti G1 GAMING 4GB GDDR5 PCIe3.0 Grap...
Gigabyte GeForce GTX 1050 Ti G1 GAMING 4GB GDDR5 PCIe3.0 Graphics
£213.75
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Outstanding performance
  • Unique fan design
  • Composite heat pipes
  • Durable components
  • Graphics Processor Manufacturer: NVIDIA
  • Graphics Processor: NVIDIA GeForce GTX 1050 Ti, NVIDIA GeForce GTX 1050 Ti, NVIDIA GeForce GTX 1050 Ti
  • Interface: PCI Express 3.0 x16
  • Memory Size: 4GB, 4GB
  • Digital Output: DisplayPort, Dual DVI, High-Definition Multimedia Interface (HDMI)
Product codes
GEFORCE GTX 1050
ESSENTIAL GEAR FOR EVERY GAMER
Everyone deserves great gaming. That’s why we created the fast, powerful GeForce® GTX 1050. Now, you can turn your PC into a true gaming rig, powered by NVIDIA Pascal™—the most advanced GPU architecture ever created. It’s loaded with innovative NVIDIA Game Ready technologies that let every gamer experience the latest titles in their full glory. #GameReady.
Powered by GeForce® GTX 1050 Ti
Integrated with 4GB GDDR5 128bit memory
WINDFORCE 2X with Blade Fan Design
16.8M Customizable Color RGB Lighting
Core
Boost: 1506 MHz/ Base: 1392 MHz in OC Mode
Boost: 1480 MHz/ Base: 1366 MHz in Gaming
GIGABYTE G1 Gaming Series graphics cards are crafted for perfection in pursuit of the ultimate graphics experience for gaming enthusiasts. Based on the revolutionary NVIDIA® Pascal™ GPU architecture, G1 gaming graphics card brings you incredible gaming experience.
- Pascal-powered graphics card give you superior performance and power efficiency
- Classic and modern games at 1080p @ 60 FPS
- Fast, smooth, power-efficient gaming experiences
WINDFORCE 2X Cooling System
The WINDFORCE 2X cooling system features two 90mm unique blade fans, 2 pure copper composite heat-pipes, alternate spinning fan design, and heat pipes direct touch technology, together delivering an effective heat dissipation capacity for higher performance at lower temperatures.
Alternate Spinning Fan Design
Optimize air flow by the alternate spinning fans that reduce air turbulence and effectively dissipate the heat.
Unique Blade Fan Design
The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow by 23% over traditional fans.
16.8M Customizable Color Lighting
With 16.8M customizable color options and numerous lighting effects, you could now choose the right scheme for your gaming rig through XTREME Engine utility.
One-click Super overclocking
With a simple click on XTREME engine utility, gamers can easily tune the card to meet their various gaming requirements without any overclocking knowledge, while saving the hassle of manual adjustment.
Product Description Gigabyte GeForce GTX 1050 Ti G1 Gaming 4G - OC Edition - graphics card - GF GTX 1050 Ti - 4 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 1050 Ti
Memory 4 GB GDDR5
Core Clock 1392 MHz
Boost Clock 1506 MHz
Effective Memory Clock 7.008 GHz
Memory Interface 128-bit
Max Resolution 7680 x 4320
Max Resolution Details DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported 4
Interfaces DVI-D (dual link) , DisplayPort , 3 x HDMI
API Supported DirectX 12, OpenGL 4.5
Dimensions (WxDxH) 4 cm x 21.9 cm x 11.8 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GeForce GTX 1...
£213.75
