Gigabyte GeForce GTX 980 1228MHz 4GB PCI-Express 3.0 HDMI Gaming
Key features
  • Flex Display technology
  • SOC - GPU gauntlet sorting
  • Ultra durable VGA
  • Lower GPU Temperature
  • Better overclocking capability
  • Decrease power switching loss
Product codes
Gigabyte Windforce 3X 600W cooling system once again break the record and bring the air cooling capacity up to 600W by only using 2 slots heights. The Windforce 3X 600W cooling system is equipped with five 8mm and one 6mm composite cooper heat-pipes, special fin architecture, unique blade fan design, and Gigabyte "Triangle Cool" technology. This not only provides an effective heat dissipation capacity but also enables higher performance due to a lower temperature.
  • WINDFORCE 3X 600W cooling system
  • Flex Display Technology(patent-pending)
  • Powered by NVIDIA GeForce GTX 980 GPU
  • Integrated with industry's best 4GB GDDR5 memory 256-bit memory interface
  • Features Dual-link DVI-I / DVI-D / HDMI / DisplayPort*3
  • BASE: 1228 MHz / BOOST: 1329 MHz(1253/1354 MHz in OC Mode)
  • System power supply requirement: 600W(with two 8-pin external power connectors)
GIGABYTE Flex display technology(patent-pending) can automatically detect any connected monitors and achieve multi-display gaming up to 4 monitors at the same time by using various output groups. Users could enjoy the best gaming experience in ultra HD resolution with extended flexibility in arranging monitor configurations and making future system upgrade extremely easy.
With GPU Gauntlet™ Sorting, the Gigabyte SOC graphics card guarantees the higher overclocking capability in terms of excellent power switching.
Product Description Gigabyte GV-N980G1 GAMING-4GD (rev. 1.0/1.1) - graphics card - GF GTX 980 - 4 GB
Device Type Graphics card
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 980
Memory 4 GB GDDR5
Core Clock 1228 MHz
Boost Clock 1329 MHz
Effective Memory Clock 7 GHz
Memory Interface 256-bit
Max Resolution 4096 x 2160
Max Monitors Supported 4
Interfaces DVI-I (dual link) , 3 x DisplayPort , HDMI , DVI-D (dual link)
API Supported OpenGL 4.4, DirectX 12
Dimensions (WxDxH) 4.3 cm x 31.2 cm x 12.9 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
