Gigabyte GF GV-N105TOC-4GL PCIE 3 LP
£121.64
Delivery:
Key features
  • WindForce 2x cooling system
  • Unique blade fan design
  • 3D active fan
  • One-click super overclocking
  • Ultra-cooling
  • Low power loss
  • Longer life
  • Intuitive XTREME engine utility
  • Graphics Processor Manufacturer: NVIDIA
  • Graphics Processor: NVIDIA GeForce GTX 1050 Ti, NVIDIA GeForce GTX 1050 Ti, NVIDIA GeForce GTX 1050 Ti
  • Interface: PCI Express 3.0 x16
  • Memory Size: 4GB, 4GB
Product codes
The WindForce 2x cooling system features two unique blade fans and semi-passive 3D active fan together delivering an effective heat dissipation capacity for higher performance at lower temperatures. The airflow is spilt by the triangle fan edge, and guided smoothly through the 3D stripe curve on the fan surface, effectively enhancing the air flow. The semi-passive fans will remain off when the GPU is under a set loading or temperature for low power gaming. It allows gamers to enjoy gameplay in complete silence when the system is running light or idle.
Product Description Gigabyte GeForce GTX 1050 Ti OC 4G - graphics card - GF GTX 1050 Ti - 4 GB
Device Type Graphics card - low profile
Bus Type PCI Express 3.0 x16
Graphics Engine NVIDIA GeForce GTX 1050 Ti
Memory 4 GB GDDR5
Core Clock 1328 MHz
Boost Clock 1442 MHz
Effective Memory Clock 7.008 GHz
Memory Interface 128-bit
Max Resolution 7680 x 4320
Max Resolution Details DisplayPort: 7680 x 4320 at 60 Hz/ HDMI: 4096 x 2160 at 60 Hz
Max Monitors Supported 4
Interfaces DVI-D (dual link) , DisplayPort , HDMI
API Supported DirectX 12, OpenGL 4.5
Dimensions (WxDxH) 3.7 cm x 16.7 cm x 6.89 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GF GV-N105TOC...
£121.64
