By using this gaming mouse, GM-M6800, you can adjust 2-level DPI by clicking the quick switch button to behave in variety conditions.
To make sure Gigabyte can provide better performance, Gigabyte has adopted Dual-lens optical technology to Gigabyte's product line. With this technology, mouse can achieve higher intensity light without disperse for advanced precision. You can work on photo paper, coating, painting papers, even on glass boards!
Want to surfing the web? GM-M6800 will be your best partner. Simply click on its hot keys will allow you to surfing back and forward easily on web. Too tired to use computer after work? GM-M6800 is designed ergonomically. Feeling comfortable by using this mouse no matter how long you play with it. No matter playing games or web surfing, GM-M6800 will definitely be your best choice.
Dual Lens technology features advanced precision
800/ 1600 DPI on-the-fly adjustable
Ergonomic shape with comfortable rubber grips
Ultra-smooth Teflon feet pads
Product Description | Gigabyte GM-M6800 - mouse - USB - noble black | Device Type | Mouse | Connectivity Technology | Wired - USB | Colour | Noble black | Dimensions (WxDxH) | 7.5 cm x 12.7 cm x 4.3 cm | Weight | 126 g | Movement Detection Technology | Optical | Buttons Qty | 5 | Movement Resolution | 1600 dpi | Performance | 3000 fps | Features | Dual lens | Cables Included | 1 x USB cable - integrated - 1.5 m | OS Required | Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista |
General | |
Width | 7.5 cm |
Depth | 12.7 cm |
Height | 4.3 cm |
Weight | 126 g |
Input Device | |
Connectivity Technology | Wired |
Interface | USB |
Buttons Qty | 5 |
Expansion / Connectivity | |
Interfaces | 1 x USB - 4 pin USB Type A |
Miscellaneous | |
Compliant Standards | BSMI, FCC |
Software / System Requirements | |
