Gigabyte GM-M6800 Dual Lens Gaming Mouse - optical - 5 button...
Gigabyte GM-M6800 Dual Lens Gaming Mouse - optical - 5 button - USB
Key features
  • Best C/P value for gaming user
  • Features dual lens solution for advanced precision
  • 1600 dpi high-definition optical technology - delivers 2-4 times sensitivity of standard optical mice, experience smooth, precise tracking
  • DPI adjustable - 2-level sensitivity switching
  • Total-comfort design - equipped with soft rubber grips and contoured shape to provide superior grasp during the longest gaming sessions
  • Super-smooth feet - slide easily across almost any surface
Product codes
By using this gaming mouse, GM-M6800, you can adjust 2-level DPI by clicking the quick switch button to behave in variety conditions.
To make sure Gigabyte can provide better performance, Gigabyte has adopted Dual-lens optical technology to Gigabyte's product line. With this technology, mouse can achieve higher intensity light without disperse for advanced precision. You can work on photo paper, coating, painting papers, even on glass boards!
Want to surfing the web? GM-M6800 will be your best partner. Simply click on its hot keys will allow you to surfing back and forward easily on web. Too tired to use computer after work? GM-M6800 is designed ergonomically. Feeling comfortable by using this mouse no matter how long you play with it. No matter playing games or web surfing, GM-M6800 will definitely be your best choice.
Dual Lens technology features advanced precision
800/ 1600 DPI on-the-fly adjustable
Ergonomic shape with comfortable rubber grips
Ultra-smooth Teflon feet pads
Product Description Gigabyte GM-M6800 - mouse - USB - noble black
Device Type Mouse
Connectivity Technology Wired - USB
Colour Noble black
Dimensions (WxDxH) 7.5 cm x 12.7 cm x 4.3 cm
Weight 126 g
Movement Detection Technology Optical
Buttons Qty 5
Movement Resolution 1600 dpi
Performance 3000 fps
Features Dual lens
Cables Included 1 x USB cable - integrated - 1.5 m
OS Required Microsoft Windows 98/ME/2000/XP, Microsoft Windows Vista
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
