Gigabyte GZ-G2 Gaming Case Plus with USB 3.0 Ports & 2 Fr...
Gigabyte GZ-G2 Gaming Case Plus with USB 3.0 Ports & 2 Front Fans
Key features
  • One extra cooling fan, dissipating the hot air more efficiently
  • Thoughtful tray design, reserving place for your own stuff
  • Two USB 3.0 ports at the top for easy access
  • High quality CD-ROM bezel to keep the front look uniform
  • Control on/off of the fan with just a push on the button
  • Reset button for easy system re-boot
  • Two 12 cm intake fans for a better cooling solution
  • Water cooling holes for future upgradability
  • Pedestal foots providing stability and protecting your table/floor from scratches
Product codes
New Gaming Case from Gigabyte for 2012 with USB 3.0 ports
  • GZ-G2 Plus with 2 x 120mm front Cooling fans
  • 1 x 120mm Top cooling fan to disspate hot air more efficiently
  • Tray design to top of case to hold smart phones and digital equipment
  • 2 x USB 3.0 ports at top for easy access
  • Control on/off button for fans on front of case
  • Multi media panel located at the front middle for easy access with reset button
  • Tool-less installation for 5.25 / 3.5 Devices
  • 80mm rear exhaust fan
  • Water cooling holes for future upgradability for liquid cooling
  • Convex side panel at the back of motherboard for hiding extra cables
  • Power supply positioned at bottom
  • Ventilation holes and dust filter for PSU
  • Black coated interior
  • Space for 2 x 120mm fans on the side panel
  • Pedestal foots provide stability and protect floor from scratches
Specification
  • Model no. GZ-G2 Plus
  • Dimensions ( W x H x D ) 185 x 420 x 445 mm
  • Material ABS / Mesh/ 0.6 mm SGCC
  • Color (s) Black
  • Side panel (s) TAC 2.0
  • Drive bays 5.25" x1 , 3.5"x1 +6(internal)
  • Expansion slots 7
  • Form factor ATX / Micro ATX
  • I / O ports 2 x USB 2.0 / 1 x HD Audio / 2 x USB 3.0
  • Fans Front: 120mm silent fan x 2 (w/ fan switch x 2) / Rear: 80mm silent fan x1 / Top: 120mm silent fan x 1
  • Weight 5.78kg
Product Description Gigabyte GZ-G2 Plus - tower - ATX
Product Type System cabinet
Form Factor Tower
Colour Black
I/O Connectors 2 x USB 2.0 , 2 x audio , 2 x USB 3.0
Supported Motherboards ATX, microATX
System Cabinet Features Screwless drive bays, TAC2.0 (Thermally advantaged chassis version 2.0), rear dust filter, water cooling holes
Power Device No power supply
Weight 5.8 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte GZ-G2 Gaming...
