Gigabyte M6980X Laser Gaming Mouse
£32.55
Delivery:
Key features
  • 6000dpi gaming-grade laser sensor
  • Built-in GHOST Engine supports 3 macro profiles on the go
  • Tracking capability and image processing up to 12000fps
  • 4-direction tilt wheel functionality
Product codes
  • Built-in GHOSTTM Engine supports 3 macro profiles on the go
Powered by 6000dpi Advanced Gaming Laser Sensor
Professional-grade laser sensor offers lightning fast 12,000 fps image processing capability for absolute control and precise mouse movement.
*Standard mice has 3000 FPS image processing capability
Built-in GHOSTTM Macro Engine
GHOSTTM macro engine which features intuitive interface allows you to pre-define up and switch between 9 programmable buttons easily for latest PC gaming titles. Onboard memory supports 3 macro profiles memorization for the gamer on the go.
4-direction Tilt Wheel Functionality
Versatile 4-direction tilt wheel for quick and easy desktop navigation. They are also programmable through GHOSTTM engine software.
*You may have to download GHOST engine software first to enjoy the complete function.
3-Stage DPI Adjustment
800/1600/5600 3-Stage DPI adjustable switch with 3-Stage LED indicators for quick on-the-fly DPI adjustment
*The hardware based sensitivity up to 5600dpi and software enhanced up to 6000dpi.
Anti-slick Rubber Grip with Ideal Shape for comfortable Gameplay
Anti-slick ergonomic rubber grip reduces wrist strain and maximizes comfort during extended use.
Ultra-durable USB Cable
1.8M ultra durable cable with gold plated USB connector ensures stable and optimum signal transfer.
Non-slick Coating
Moisture-resistant non-slick coating for exceptional comfort during extended gameplay sessions.
Gaming Grade Feet Pads
Teflon gaming grade feet pads for improved accuracy and freedom of movement.
Gigabyte M6980X - mouse - USB - black
Mouse
Wired - USB
7.76 cm x 12.45 cm x 4.18 cm
106 g
Movement Detection Technology
Laser
Movement Resolution
6000 dpi
Performance
30 G maximum acceleration, 12000 fps, 150 inches per second
Scrolling wheel, golden USB plug
1 x USB cable - integrated - 1.8 m
Microsoft Windows Vista / XP / 7
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte M6980X Laser...
£32.55
