Gigabyte X299-UD4 Intel X299 S2066 DDR4 M.2 USB3.1 PCIex16 ATX
Key features
  • Do more with your fastest cores
  • Set the color that matches your style
  • RGB Fusion with Digital LEDs
  • Independently programmable onboard pin header for RGBW/-UV LED strips
  • ALC 1220 120 dB SNR HD audio
  • Smart headphone AMP
  • Smart Fan 5
  • Fan Stop
Product codes
The GIGABYTE X299 enthusiast motherboards are faster and more powerful. With an aggressively redesigned thermal heatsinks its sure to turn heads and catch eyes. Performance is no stranger to GIGABYTE, with exotic cooling and an ability to be tuned to peak performance GIGABYTE motherboards will exceed expectations.
Product Description Gigabyte X299 UD4 - 1.0 - motherboard - ATX - LGA2066 Socket - X299
Product Type Motherboard - ATX
Chipset Type Intel X299 Express
Processor Socket 1 x LGA2066 Socket
Compatible Processors Core X
Max RAM Size 512 GB
RAM Supported 8 DIMM slots - DDR4 registered, unbuffered
Storage Ports 8 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports USB 3.1 Gen 1, USB 3.1 Gen 2 2 x USB 3.1 Gen 2 + 6 x USB 3.1 Gen 1 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte X299-UD4 Inte...
