Gigabyte Z370 AORUS Gaming 3 Intel Z370 S1151 DDR4 DualM.2 ATX
Key features
  • Supports 8th Gen Intel Core processors
  • Dual channel Non-ECC unbuffered DDR4, 4 DIMMs
  • Intel Optane Memory ready
  • ASMedia 3142 USB 3.1 Gen 2 with USB Type-C and Type-A
  • Front USB 3.1 Gen 1 Type-C header
  • Multi-way graphics support with PCIe armor and ultra durable design
  • ALC1220 120 dB SNR HD audio with smart headphone AMP and WIMA audio capacitors
  • Killer E2500 gaming network
  • RGB FUSION with multi-zone digital LED light show design, support digital LED & RGB LED strips
  • Smart Fan 5 features multiple temperature sensors and hybrid fan headers with FAN STOP
  • Dual Ultra-Fast M.2 with PCIe Gen3 x4 & SATA interface
  • Anti-sulfur resistors design
  • Ultra durable 25 kV ESD and 15 kV Surge LAN protection
  • Lightning-fast Intel Thunderbolt 3 AIC support
Product codes
The AORUS Z370 enthusiast motherboards are faster and more powerful than any other motherboards the world has seen. With aggressively redesigned armor and thermal heatsinks, its performance capabilities and durability are second to none. Performance is no stranger to AORUS, with exotic cooling and an ability to be tuned to peak performance, AORUS motherboards will exceed expectations.
With AORUS Z370 Motherboards, RGB Fusion is even better with Digital LEDs. RGB Fusion offers users the option to control onboard RGB and external RGBW/Digital LED light strips for their PC. Already feature filled with colors and patterns, RGB Fusion on Z370 Series AORUS Motherboards are now upgraded with Digital LED support. With external digital LED strips, where each LED is digitally addressable, users can experience even more patterns, styles, and illuminations. AORUS Gaming Motherboards will support either 5 V or 12 V digital LED lighting strips and up to 300 LED lights. RGB Fusion with Digital LEDs comes with 9 patterns and various speed settings with more to come.
Not bright enough? You can install standard 12 V external RGB, RGBW or RGB/UV light strips on the RGBW pin header and control its color from the RGB Fusion software. Using a RGBW light strip with a dedicated white LED, users will experience brighter and more vibrant shades of colors. When using RGB/UV LED strips, users can give their systems a fluorescent glow with the use of UV reactive liquid, neon braided cables, and acrylic paint for a wicked-looking gaming PC. No need to worry when choosing light strips as AORUS motherboards support a wide variety of RGBW/-UV light strips on the market thanks to the RGB Fusion software that allows users to redefine the pin location for the R/G/B Signal.
Gigabyte Z370 AORUS Gaming 3 - 1.0 - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports
USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2, USB-C Gen1 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (1 x USB-C Gen 1 + 2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte Z370 AORUS Ga...
