Gigabyte Z370 HD3P Intel Z370 S1151 DDR4 Dual M.2 USB3.1G2 ATX
Key features
  • Smart Fan 5
  • Smart headphone AMP
  • High-end audio capacitors
  • Audio noise guard
  • 2-Way CrossFire multi-graphics
Product codes
Marketing description is not available.
Product Description Gigabyte Z370 HD3P - 1.0 - motherboard - ATX - LGA1151 Socket - Z370
Product Type Motherboard - ATX
Chipset Type Intel Z370
Processor Socket 1 x LGA1151 Socket
Compatible Processors Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4 unbuffered
Storage Ports 6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2, USB-C Gen1 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (1 x USB-C Gen 1 + 2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size 1 GB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte Z370 HD3P Int...
