Gigabyte Z370P D3 Intel Z370 S1151 DDR4 M.2 USB3.1 ATX
£87.58
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Smart Fan 5
  • 2-Way CrossFire multi-graphics
  • High-end audio capacitors
  • Audio noise guard
Product codes
With Smart Fan 5 users can ensure that their gaming PC can maintain its performance while staying cool. Smart Fan 5 allows users to interchange their fan headers to reflect different thermal sensors at different locations on the motherboard. Not only that, with Smart Fan 5 more hybrid fan headers that support both PWM and Voltage mode fans have been introduced to make the motherboard more liquid cooling friendly. Multi-graphics configuration offers better graphics performance for gaming enthusiasts who demand the high frame rates without compromising on resolution. GIGABYTE motherboards use high-end audio capacitors. These high quality capacitors help deliver high resolution and high fidelity audio to provide realistic sound effects for gamers. GIGABYTE Z370 motherboards feature an audio noise guard that essentially separates the board's sensitive analog audio components from potential noise pollution at the PCB level. LED trace path lighting illuminates to show the separation of the PCB layers.
Gigabyte Z370P D3 - 1.0 - motherboard - ATX - LGA1151 Socket - Z370
Motherboard - ATX
Chipset Type
Intel Z370
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4 unbuffered
Storage Ports
6 x SATA-600 (RAID), 1 x M.2
USB / FireWire Ports
USB 3.1 Gen 1 4 x USB 3.1 Gen 1 + 2 x USB 2.0 + (2 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size
1 GB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte Z370P D3 Inte...
£87.58
