Gigabyte Z370XP SLI Intel Z370 S1151 DDR4 Dual M.2 USB3.1G2 ATX
Key features
  • Smart Fan 5
  • Fan Stop
  • ALC 1220 120 dB SNR HD audio
  • High-end audio capacitors
  • Audio noise guard
  • Dual PCIe Gen3 x4 M.2
  • Intel GbE LAN with cFosSpeed Internet accelerator networking
  • 2-way SLI / 3-way CrossFire multi-graphics
Product codes
Marketing description is not available.
Product Description Gigabyte Z370XP SLI - 1.0 - motherboard - ATX - LGA1151 Socket - Z370
Product Type Motherboard - ATX
Chipset Type Intel Z370
Processor Socket 1 x LGA1151 Socket
Compatible Processors Core i5, Core i3, Core i7 (supports 8th Generation Intel Core i3 / i5 / i7)
Max RAM Size 64 GB
RAM Supported 4 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports 6 x SATA-600 (RAID), 2 x M.2
USB / FireWire Ports USB 3.1 Gen 1, USB-C Gen2, USB 3.1 Gen 2 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 6 x USB 3.1 Gen 1 + (4 x USB 3.1 Gen 1 + 4 x USB 2.0 via headers)
Max Allocated RAM Size 1 GB
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte Z370XP SLI In...
