Gigabyte Z68AP-D3 LGA1155 Intel Z68 DDR3 ATX USB 3.0
Key features
  • Intel Quick Sync Video
  • Intel InTru 3D
  • Intel Insider
  • Switchable graphics with LucidLogix Virtu GPU virtualization
  • An innovative new way to modify BIOS settings
  • 100% hardware VRD 12 compliant CPU power design
Product codes
The GA-Z68AP-D3 motherboard, based on the Intel Z68 Express Chipset and supporting the new 2nd generation Intel Core processors. Delivering the very best that Intel 6 series chipsets have to offer, including a significant performance boost with Intel Smart Response Technology, the first ever mSATA drive connectors on a standard desktop PC motherboard, and GIGABYTE's proprietary Touch BIOS technology, GIGABYTE Z68 series motherboards put users in the driver seat, allowing them to take total control over how their system operates and performs to best match their individual computing needs.
Onboard mSATA connector and Smart Response Technology
GIGABYTE Z68 motherboards are equipped with the much anticipated Intel® Smart Response Technology, allowing users to experience system performance similar to SSD-only systems. Intel® Smart Response technology works by using intelligent block-based caching of frequently used applications to improve system performance and responsiveness. In fact, GIGABYTE Z68 motherboards with Intel® Smart Response Technology are able to outperform hybrid drive systems by more than 2X (PC Mark Vantage HDD test) and HDD-only systems by as much as 4X (PC Mark Vantage HDD test) and deliver a 60% performance improvement over HDD-only systems in PC Mark Vantage Suite.
Built-in Visuals
Built-in Visuals GIGABYTE Z68 motherboards offer support for several 2nd generation Intel® Core™ Built-in Visual Features.
Intel® Quick Sync Video
Up to 2X faster media processing than any other solution for incredibly fast conversion of video files for portable media players or online sharing.
Intel® InTru™ 3D
Users can enjoy the ultimate 3D visual experiences-seamlessly-from their PC. Now they can watch their favorite 3D movies with Blu-ray Stereo 3D playback using active shutter 3D glasses. It delivers it all in 1080p full, high-definition resolution on the TV over HDMI 1.4.
Intel® Insider
Allows users to view premium 1080p HD content on their GIGABYTE Z68 series system.
Switchable Graphics with LucidLogix Virtu GPU Virtualization
GIGABYTE Z68 motherboards are enabled with LucidLogix Virtu GPU Virtualization technology which allows users to dynamically switch between their built-in graphics and their high-end, 3D discrete graphics cards. This is ideal for gamers who require high-resolution gaming and still want to enjoy the built-in media features of 2nd generation Intel® Core™ processors. In so doing, switchable graphics helps to dramatically reduce PC graphics power consumption.
SuperSpeed USB 3.0
GIGABYTE motherboards boast SuperSpeed USB 3.0 technology made possible through an additional onboard host controller. With superfast transfer rates of up to 5 Gbps, users are able to experience a theoretical 10x improvement over USB 2.0. Additionally, backwards compatibility with USB 2.0 assures users of long term use of their legacy USB 2.0 devices.
SATA 6 Gbps
GIGABYTE motherboards are High-Speed SATA Revision 3.0 compatible, delivering superfast 6Gbps link speeds for twice the data transfer rates of SATA Revision 2.0 (3 Gbps). When used in RAID 0 (Stripe) mode, they offer even faster data transfer rates of up to a theoretical 4x the speed of current SATA interfaces.
Product Description Gigabyte GA-Z68AP-D3 - 1.0 - motherboard - ATX - LGA1155 Socket - Z68
Product Type Motherboard - ATX
Chipset Type Intel Z68 Express / ITE IT8728
Processor Socket 1 x LGA1155 Socket
Compatible Processors Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size 32 GB
RAM Supported 4 DIMM slots - DDR3, non-ECC
Storage Ports 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
USB / FireWire Ports USB 3.0 2 x USB 3.0 + 4 x USB 2.0 + (6 x USB 2.0 via headers)
Audio HD Audio (8-channel)
LAN Gigabit Ethernet
Microsoft Certification Compatible with Windows 7
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Gigabyte Z68AP-D3 LGA1...
