Google Chromecast (2018)
FREE DELIVERY
STREAM FROM ANDROID AND IPHONE
£30.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • See your laptop on your TV
  • Command your TV from your tablet
  • Start streaming by speaking
  • Stock Status: In Stock, Used Stock
Product codes
Bundle deals (1)
CONTROL YOUR TV USING YOUR VOICE WITH GOOGLE HOME AND CHROMECAST
= £119.00
Welcome to Chromecast.
Stream on.
Stream from your device to your TV. Just like that.
Plug Chromecast into the HDMI port on your TV and to power and stream your favorite entertainment right from your phone with just a tap. Watch shows, listen to playlists, and more. And while streaming, you can still use your phone as you normally do.
Stream from Android and iPhone®.
Enjoy hundreds of Android or iPhone apps, and play or pause directly from your phone.
Watch BT Sport app on your TV
Get the best of both worlds with BT Sport app plus Google Chromecast. It lets you stream from the app to your TV when you’re at home, and you can still watch the BT Sport app on your device while out and about.
See your laptop on your TV.
Mirror your laptop screen to your TV with your Chrome browser. Surf the web or see your media on the big screen.
Command your TV from your tablet.
Turn your Android or iOS tablet into an even better entertainment center. Just tap the Cast button in any compatible app.
Want to stream music to your TV?
Use the Cast button to stream to your TV from compatible music services like Spotify and YouTube Music.
Put your voice in charge.
Start streaming by speaking.
Use your voice to stream from compatible apps, mute the volume, rewind, and more with Chromecast and Google Home.
See your Nest cameras on your TV.
Check your Nest cameras and Nest Hello video doorbell from your couch with Chromecast and Google Home.
Specs
Dimensions:
Length: 52 mm
Width: 0.54 in (13.8 mm)
Diameter: 51.9 mm
Power cable: 1.52 m
Weight: 1.41 oz (40 g)
Resolution: Up to 1080p 60fps
Wireless: Wi-Fi 802.11ac (2.4 GHz/5 GHz)
Power: 5 V, 1 A power supply
Ports & Connectors: HDMI, Micro-USB
Supported operating systems: Android, iOS, Mac, Windows
What's in the box:
Chromecast
Power cable
Power adapter
Requirements:
TV with an HDMI port
Wi-Fi network
Wi-Fi-enabled supported device
Product Description Google Chromecast 3 - digital multimedia receiver
Product Type Digital multimedia receiver
Enclosure Colour Charcoal
Source Network
Supported Resolutions 1920 x 1080 - 60fps
Interfaces Wi-Fi
Dimensions (WxDxH) 5.18 cm x 5.18 cm x 1.38 cm
Weight 40 g
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: DWT3 041620
£27.18
product
Ref: DWT3 041620
Accessories
Packaging
Functional
Software
Manuals
£27.18
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£30.00
