Google Home Max - Chalk
FREE DELIVERY
£299.00
Colours:
Delivery:
Standard: 1-3 working days
Express: Delivered on Monday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Acoustically transparent fabric
  • Dual woofers for deep, balanced bass
  • Rigid housing to keep the audio composed
  • Custom tweeters for crystal-clear highs
  • Type: Smart Speaker
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
Built for sound, inside and out.
Meet the new Google Home Max.
Feel the music.
Google Home Max is made for the ultimate in high fidelity.
Dual 4.5" woofers for deep, balanced bass
Introducing Smart Sound.
With Smart Sound, Google Home Max uses machine learning to automatically adjust the equaliser settings to match the acoustics of your room. This gives you the most balanced sound – wherever you put it.
35+ million songs at your command.
Play your favourites from YouTube Music, Spotify, Pandora and more.
Say what you want to hear.
With far-field voice control, Max can hear you across the room, even while your music is playing.
Play it your way.
Stream over Wi-Fi from compatible apps on your phone or laptop, play songs right over Bluetooth® or plug in your record player using a stereo cable.
Just as helpful.
Max gives you hands-free help from the Google Assistant. Ask it questions, tell it to do things and even control smart home devices.
Sync up speakers in your house.
Max connects with other Google Home devices and your speakers using Chromecast Audio, so that you can blast your tunes throughout the house.
Specs
Dimensions:
Width: 336.6 mm (13.2 in)
Height: 190.0 mm (7.4 in)
Depth: 154.4 mm (6.0 in)
Power cable: 2 m (6.56 ft)
Weight: 5,300g (11.7 lbs)
Materials:
Rigid polycarbonate housing
Silicone base
Supported audio formats:
HE-AAC, LC-AAC+, MP3, Vorbis, WAV (LPCM), FLAC, Opus
Wireless:
802.11b/g/n/ac (2.4GHz/5Ghz) Wi-Fi for high-performance streaming
Chromecast built-in
Bluetooth® 4.2
Speaker:
Two 114 mm (4.5 in) high-excursion (+/- 11 mm) dual voice-coil woofers
Two 18 mm (0.7 in) custom tweeters
Sealed rigid housing
Mics:
Far-field voice recognition supports hands-free use
Processor:
1.5 GHz 64-bit quad-core ARM® Cortex™ A53
Sensors:
Ambient light sensor
Orientation sensor
Power:
AC Power 100-240 V, 50/60 Hz
Ports & Connectors:
USB-C
3.5-mm jack with analogue audio input
AC power
Supported operating systems:
Android 5.0 and higher
iOS® 9.1 and higher
Other:
Multi-room audio
Wireless stereo pairing
What's in the box:
Google Home Max
Quick Start Guide
Power cable
Magnetic base
Requirements:
Wi-Fi use requires 802.11a/b/g/n/ac access point (router)
Google Home app running on a compatible mobile device. Minimum operating system requirements can be found at g.co/home/req.
Syncing services (such as backup) require a Google account.
Product Description Google Home Max - smart speaker
Product Type Smart speaker
Media Content Source Chromecast
Localisation United Kingdom
Enclosure Design Sealed
Speaker Type 2-way - active
Interfaces Bluetooth, Wi-Fi
Intelligent Assistant Compatible Google Assistant
Streaming Services Netflix, Deezer, Spotify, TuneIn, Google Play Music, Chromecast, YouTube MUSIC
Audio Formats WAV, MP3, FLAC, HE-AAC, OPUS, Vorbis, LC-AAC+
Speaker Details Speaker - stereo x 2 - 2-way - active
Colour Chalk
Power AC 100 - 240 V (50/60 Hz)
Dimensions (WxDxH) 33.66 cm x 15.44 cm x 19 cm
Weight 5.3 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£299.00
