Google Home Max - Chalk
FREE DELIVERY
£299.00
Colours:
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Acoustically transparent fabric
  • Dual woofers for deep, balanced bass
  • Rigid housing to keep the audio composed
  • Custom tweeters for crystal-clear highs
  • Type: Smart Speaker
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
Meet the Google Home Max.
Meet Google Home Max, our biggest and best sounding Google Home with the Google Assistant built-in. With a combination of hardware and Smart Sound software, Max makes your music sound great. Pure and simple. However you want to play your music, Max has you covered. And in any room you have a Google Home device, you can group them together to play your music in sync.
Feel the music.
Google Home Max is made for the ultimate in high fidelity.
Dual 4.5" woofers for deep, balanced bass
Built for sound, inside and out.
Google Home Max is designed with advanced hardware for room-filling stereo sound. With two 4.5" woofers that offer 22mm of excursion, it can hit a wide range of low frequencies. Plus, Max is built with a sealed, rigid polycarbonate housing and an acoustic brace to reduce distortion. So there’s no unwanted resonance or muddiness, even when you crank up the volume. To make sure Max can still hear you over the music, far-field mics are optimized for high volumes. Stand up Max vertically or place it down horizontally. Whichever orientation you choose, a built-in sensor ensures lifelike performance.
Smart Sound. Better Music.
Smart Sound adapts the listening experience to you - not the other way around. Using six internal microphones to measure the acoustics of your room, Google Home Max automatically adjusts the equalizer settings for the most balanced sound.
Play it your way.
Enjoy music in all ways you like. Stream 40+ million songs over Wi-Fi from YouTube Music, Spotify, Pandora, iHeartRadio and more. Since it’s made by Google, simply use your voice to search, play and control your music. With excellent far-field voice recognition, Max can hear you from across the room, even with the music turned up.
Expand your sound.
Get that home sound system you’ve been craving. Group Max with compatible speakers like Google Home to play the same song in sync across multiple rooms. Or wirelessly stereo-pair two Maxes together.
Just as helpful.
With the Google Assistant built-in, Google Home Max is your own personal DJ. Just say what you want to hear. Plus, get real-time answers to things you want to know, control smart devices in your home, or use Max to set reminders, send messages or make phone calls, hands free.
Multi-device hotwording
With more than one device, you don’t need to worry about all of them responding when you say, "Ok Google" — if they have the same user account, all of them will listen but only the closest one will respond.
Automatic updates
As new features continue to roll out, they’ll get added automatically.
Far-field voice
Far-field microphones and industry-leading natural language processing ensure Google Home hears you reliably.
Touch controls
The top touch surface gives you total control, and a mute button lets you put Google Home's microphones on standby.
Specs
Dimensions:
Width: 336.6 mm (13.2 in)
Height: 190.0 mm (7.4 in)
Depth: 154.4 mm (6.0 in)
Power cable: 2 m (6.56 ft)
Weight: 5,300g (11.7 lbs)
Materials:
Rigid polycarbonate housing
Silicone base
Supported audio formats:
HE-AAC, LC-AAC+, MP3, Vorbis, WAV (LPCM), FLAC, Opus
Wireless:
802.11b/g/n/ac (2.4GHz/5Ghz) Wi-Fi for high-performance streaming
Chromecast built-in
Bluetooth® 4.2
Speaker:
Two 114 mm (4.5 in) high-excursion (+/- 11 mm) dual voice-coil woofers
Two 18 mm (0.7 in) custom tweeters
Sealed rigid housing
Mics:
Far-field voice recognition supports hands-free use
Processor:
1.5 GHz 64-bit quad-core ARM® Cortex™ A53
Sensors:
Ambient light sensor
Orientation sensor
Power:
AC Power 100-240 V, 50/60 Hz
Ports & Connectors:
USB-C
3.5-mm jack with analogue audio input
AC power
Supported operating systems:
Android 5.0 and higher
iOS® 9.1 and higher
Other:
Multi-room audio
Wireless stereo pairing
What's in the box:
Google Home Max
Quick Start Guide
Power cable
Magnetic base
Requirements:
Wi-Fi use requires 802.11a/b/g/n/ac access point (router)
Google Home app running on a compatible mobile device. Minimum operating system requirements can be found at g.co/home/req.
Syncing services (such as backup) require a Google account.
Product Description Google Home Max - smart speaker
Product Type Smart speaker
Media Content Source Chromecast
Localisation United Kingdom
Enclosure Design Sealed
Speaker Type 2-way - active
Interfaces Bluetooth, Wi-Fi
Intelligent Assistant Compatible Google Assistant
Streaming Services Netflix, Deezer, Spotify, TuneIn, Google Play Music, Chromecast, YouTube MUSIC
Audio Formats WAV, MP3, FLAC, HE-AAC, OPUS, Vorbis, LC-AAC+
Speaker Details Speaker - stereo x 2 - 2-way - active
Colour Chalk
Power AC 100 - 240 V (50/60 Hz)
Dimensions (WxDxH) 33.66 cm x 15.44 cm x 19 cm
Weight 5.3 kg
Manufacturer Warranty 2 year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
£299.00
