Google Home Mini - Smart Speaker - Chalk
FREE DELIVERY
£49.00
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered tomorrow
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • A powerful little helper
  • Get answers from Google
  • Manage your day from breakfast to bed
  • Play, pause and rewind, hands-free
  • Control your smart home
  • Your voice, your info
  • Type: Smart Speaker
  • Compatible With: Google Assistant
  • Stock Status: In Stock
Product codes
Small and mighty.
Say hello to Google Home Mini.
• Keeps you informed and up to date: Instant news, weather and commute updates without lifting a finger.
• Master the kitchen: Helps you with timers, step-by-step recipes, and conversions and substitutes.
• Start your smart home: Always improving with seamless connections to the latest compatible smart lights and thermostats.
A powerful little helper.
Get hands-free help in any room. Google Home Mini is powered by the Google Assistant, so that you can ask it questions and tell it to do things. Just start by saying, "Ok Google".
Get answers from Google.
Just by using your voice, get the latest weather, traffic, finance, news, sports and more. Ask for things like translations, calculations, nutrition information and unit conversions. Or find other information that you’re curious about with the power of Google Search built right in.
Manage your day from breakfast to bed.
Get personalised help managing your schedule, commute and more whenever Google Home Mini recognises your voice. (With your permission, of course.) Plus, use it to set alarms, timers and reminders and listen to news and radio stations.
Play, pause and rewind. Hands-free.
Control compatible entertainment hands-free from the comfort of your sofa. Google Home Mini works with your Chromecast so that you can start streaming shows, movies and music from compatible content providers on your TV or speakers with just your voice.
Control your smart home with just a few words.
Use your voice to control compatible lights, thermostats, switches and more from your favourite home automation systems, like Philips Hue, Nest and Samsung SmartThings.
Your voice. Your info.
The Google Assistant provides information that’s personalised just for you since it can distinguish your voice from others.
Choose between different colours.
Google Home Mini comes in two unique colours, Chalk and Charcoal. Select the right colour that matches your room and personal style.
Tech Spec
Dimensions:
Diameter: 98mm (3.86 in)
Height: 42 mm (1.65 in)
Power cable: 1.5 m (4.92 ft)
Weight:
Device: 173 gm (6.1 oz)
Power adapter and cable: Approximately 75 gm (2.65 oz)
Colour:
Chalk
Materials:
Durable fabric top
Non-skid silicone base
Plastic housings created using recycled material
Supported Audio Formats:
HE-AAC
LC-AAC+
MP3
Vorbis
WAV (LPCM)
FLAC
Wireless:
802.11b/g/n/ac (2.4GHz/5Ghz) Wi-Fi
Audio:
Far-field voice recognition supports hands-free uses
360 sound with 40mm driver
Chromecast and Chromecast Audio built-in
Bluetooth® support
Power:
5V, 1.8A
Ports & Connectors:
Micro USB port
Supported Operating Systems:
Android 4.2 and higher
iOS 9.1+ and higher
Requirements:
Wi-Fi use requires 802.11 a/b/g/n/ac access point (router)
Google Home app running on a compatible mobile device
What’s in the box:
Google Home Mini
Quick Start Guide
Power adaptor and cable
Product Description Google Home Mini - smart speaker
Product Type Smart speaker
Speaker Type Active
Intelligent Assistant Compatible Google Assistant
Manufacturer Warranty 2 Year Warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Google Home Mini - Sma...
£49.00
