We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Wired
Know more.
Spot what matters.
A floodlight meets a security camera meets intelligence.
Shine a brighter light on what’s happening.
Built-in intelligent alerts help you know and see what's relevant. Tell the difference between people, vehicles, and animals.
Light a path when you need it.
Two LED lights and 180° motion detection add brightness and flexibility, so virtually nothing will go undetected.
Check in on your home in crisp HDR.
Use the Google Home app to see what’s happening near your floodlight 24/7 in 1080p HDR video. Night vision helps you see in low light.
Look back with ease.
Need to review something you missed? Look back with up to three hours of event video history included.
Make the floodlight yours.
Create routines and adjust brightness, sensitivity and how long the light stays on.
Quickly take action.
Turn it on with your voice and talk through the camera if you need to.
Keep your data safe and secure.
Two-step verification enhances security, and the green LED light lets you know that it’s recording.
2 Year Warranty
Product Description | Google Nest Cam (2021) with Floodlight (Wired) | Device Type | Network surveillance camera - fixed - outdoor - weatherproof (IP54) | Packaged Quantity | 1 | Audio | Yes; built in high quality speaker and microphone, 2-way audio capacity with noise cancellation | Camera Mount Type | Wall; fixed. Replaced existing wired floodlight, mounts onto an electrical box | Dimensions | Camera: 8.3cm (L) x 8.3cm (D) , Floodlight: 16.5cm (L) x 31.5cm (W) x 9.3cm (H) | Weight | Camera: 398g, Floodlight: 1165g | Colour | Snow | Connective Technology | Wireless | Camera | Colour: day and night , 1/2.8" megapixel sensor, 6x digital zoom, 130° diagonal field of view, 16:9 aspect ratio | Max Resolution | 1080p | Max Frame Rate | 30fps | Motion Detection | Yes. Camera: Single motion sensor, 110° horizontal field of view, up to 7.5m. Floodlight: Two motion sensors, 180° horizontal field of view, up to 7.5m | Video modes | 1080p/30fps, HDR, 24/7 live view, night vision with HDR, H.264 encoding | Wireless | 802.11a/b/g/n (2.4GHz) Wifi - WEP,WPA,WPA2,WPA3 encryption supported - Bluetooth Low Energy (BLE) | Platform | Google Nest | Intelligent Assistant | Google Assistant and Alexa-enabled devices | Cables Included | N/A | Manufacturer Warranty | 2-year limited warranty (details in box) | Environmental Parameters | -20°C to 40°C | Lighting | Two Lights with adjustable brightness: up to 2400 lumens brightness, 4000k colour temp. |
